[Qgis-user] QGIS 2.4 open att.table makes "noise" and works slow
    Simon Cropper
    simoncropper at fossworkflowguides.com
    Thu Jul 10 23:37:50 PDT 2014
This is just an extension of the wrong codepage.
Chatter in the forum suggests that people that use special characters in
the directory names have sound. Change the directory to just have
'ASCII' characters and all works. As I stated, rendering a symbol that
the program or OS does not understand can cause the system to behave
incorrectly.
I had a similar issue with using the degree symbol (as for Degrees
Celcius) in a spreadsheet. The whole application went mad with the image
being rendered all over the place and sound coming from the speakers.
Removing the symbol got ride of the problem.
If the file does not render then the directory name may be the issue. If
only the attribute data causes a problem it is most likely the data in
that table.
On 11/07/14 16:28, Stott, James wrote:
> Or it could be related to this?
> http://hub.qgis.org/issues/10746
> Does that describe the noise problems you are getting Lene?
> -----Opprinnelig melding-----
> Fra: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] På vegne av Simon Cropper
> Sendt: 11. juli 2014 08:23
> Til: qgis-user at lists.osgeo.org
> Emne: Re: [Qgis-user] QGIS 2.4 open att.table makes "noise" and works slow
> Hi Lene,
> There are two options...
> 1) you have a corrupt file (disk damaged; do sector check) or
> 2) your attribute data is in the wrong code page (this might sound like bells and beeps because some characters get rendered as control characters that trigger system bell).
> Both would result in the computer slowing down.
> What OS are you using? What type of file and what language is the data in? Does the geographic data get rendered OK? Any idea where the file came from and whether it is is UTF8, UTF16, CP1252, .......
> On 11/07/14 16:09, Lene Fischer wrote:
>> Hi,
>> When opening an attribute table the program starts to make a noise and
>> works very slow.
>> Any idea what´s happening.
>> Regards
>> *Lene Fischer*
>> Associate Professor
>> *Department of Geosciences and Natural Resource Management*
>> University of Copenhagen
>> MOB +45 40115084
>> lfi at ign.ku.dk <mailto:lfi at ign.ku.dk>
>> SCIENCE_bomaerke_UK
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Cheers Simon
>      Simon Cropper - Open Content Creator
>      Free and Open Source Software Workflow Guides
>      Introduction               http://www.fossworkflowguides.com
>      GIS Packages           http://www.fossworkflowguides.com/gis
>      bash / Python    http://www.fossworkflowguides.com/scripting
Cheers Simon
