[Qgis-user] QGIS 2.4 open att.table makes "noise" and works slow
Lene Fischer
lfi at ign.ku.dk
Fri Jul 11 00:30:45 PDT 2014
Thanks for all the answers.
I use Windows 7 QGIS 2.4 - 64 bit.
Correct - when I save using Ascii there are no noise and speed is back to normal.
This is a disaster, while we in Denmark use Latin1 and not Ascii.
Regards
Lene Fischer
Associate Professor
Department of Geosciences and Natural Resource Management
University of Copenhagen
MOB +45 40115084
lfi at ign.ku.dk<mailto:lfi at ign.ku.dk>
[SCIENCE_bomaerke_UK]
-----Oprindelig meddelelse-----
Fra: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Simon Cropper
Sendt: 11. juli 2014 08:38
Til: qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] QGIS 2.4 open att.table makes "noise" and works slow
This is just an extension of the wrong codepage.
Chatter in the forum suggests that people that use special characters in the directory names have sound. Change the directory to just have 'ASCII' characters and all works. As I stated, rendering a symbol that the program or OS does not understand can cause the system to behave incorrectly.
I had a similar issue with using the degree symbol (as for Degrees
Celcius) in a spreadsheet. The whole application went mad with the image being rendered all over the place and sound coming from the speakers.
Removing the symbol got ride of the problem.
If the file does not render then the directory name may be the issue. If only the attribute data causes a problem it is most likely the data in that table.
On 11/07/14 16:28, Stott, James wrote:
> Or it could be related to this?
> http://hub.qgis.org/issues/10746
> Does that describe the noise problems you are getting Lene?
> -----Opprinnelig melding-----
> Fra: qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>
> [mailto:qgis-user-bounces at lists.osgeo.org] På vegne av Simon Cropper
> Sendt: 11. juli 2014 08:23
> Til: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
> slow
> Hi Lene,
> There are two options...
> 1) you have a corrupt file (disk damaged; do sector check) or
> 2) your attribute data is in the wrong code page (this might sound like bells and beeps because some characters get rendered as control characters that trigger system bell).
> Both would result in the computer slowing down.
> What OS are you using? What type of file and what language is the data in? Does the geographic data get rendered OK? Any idea where the file came from and whether it is is UTF8, UTF16, CP1252, .......
> On 11/07/14 16:09, Lene Fischer wrote:
>> Hi,
>> When opening an attribute table the program starts to make a noise
>> and works very slow.
>> Any idea what´s happening.
>> Regards
>> *Lene Fischer*
>> Associate Professor
>> *Department of Geosciences and Natural Resource Management*
>> MOB +45 40115084
>> lfi at ign.ku.dk<mailto:lfi at ign.ku.dk> <mailto:lfi at ign.ku.dk>
>> SCIENCE_bomaerke_UK
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Cheers Simon
> Simon Cropper - Open Content Creator
> Free and Open Source Software Workflow Guides
> Introduction http://www.fossworkflowguides.com
> GIS Packages http://www.fossworkflowguides.com/gis
> bash / Python http://www.fossworkflowguides.com/scripting
Cheers Simon
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140711/b999f7f1/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140711/b999f7f1/attachment.jpg>
