[Qgis-user] QGIS 2.4 open att.table makes "noise" and works slow
Nathan Woodrow madmanwoo at gmail.com
Fri Jul 11 00:49:37 PDT 2014
Hey Lene,
Just delete the ogr_SOSI.DLL file in gdalplugins folder.
The noise is related to a error in that plugin.
Nathan
On Jul 11, 2014 5:30 PM, "Lene Fischer" <lfi at ign.ku.dk> wrote:
>  Hi,
> Thanks for all the answers.
> I use Windows 7 QGIS 2.4 - 64 bit.
> Correct - when I save using Ascii there are no noise and speed is back to
> normal.
> This is a disaster, while we in Denmark use Latin1 and not Ascii.
> Regards
> *Lene Fischer*
> Associate Professor
> *Department of Geosciences and Natural Resource Management*
> University of Copenhagen
> MOB +45 40115084
> lfi at ign.ku.dk
> [image: SCIENCE_bomaerke_UK]
> -----Oprindelig meddelelse-----
> Fra: qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] På vegne af Simon Cropper
> Sendt: 11. juli 2014 08:38
> Til: qgis-user at lists.osgeo.org
> Emne: Re: [Qgis-user] QGIS 2.4 open att.table makes "noise" and works slow
> This is just an extension of the wrong codepage.
> Chatter in the forum suggests that people that use special characters in
> the directory names have sound. Change the directory to just have 'ASCII'
> characters and all works. As I stated, rendering a symbol that the program
> or OS does not understand can cause the system to behave incorrectly.
> I had a similar issue with using the degree symbol (as for Degrees
> Celcius) in a spreadsheet. The whole application went mad with the image
> being rendered all over the place and sound coming from the speakers.
> Removing the symbol got ride of the problem.
> If the file does not render then the directory name may be the issue. If
> only the attribute data causes a problem it is most likely the data in that
> table.
> On 11/07/14 16:28, Stott, James wrote:
> > Or it could be related to this?
> > http://hub.qgis.org/issues/10746
> > Does that describe the noise problems you are getting Lene?
> > -----Opprinnelig melding-----
> > [mailto:qgis-user-bounces at lists.osgeo.org
> <qgis-user-bounces at lists.osgeo.org>] På vegne av Simon Cropper
> > Sendt: 11. juli 2014 08:23
> > slow
> > Hi Lene,
> > There are two options...
> > 1) you have a corrupt file (disk damaged; do sector check) or
> > 2) your attribute data is in the wrong code page (this might sound like
> bells and beeps because some characters get rendered as control characters
> that trigger system bell).
> > Both would result in the computer slowing down.
> > What OS are you using? What type of file and what language is the data
> in? Does the geographic data get rendered OK? Any idea where the file came
> from and whether it is is UTF8, UTF16, CP1252, .......
> > On 11/07/14 16:09, Lene Fischer wrote:
> >> Hi,
> >> When opening an attribute table the program starts to make a noise
> >> and works very slow.
> >> Any idea what´s happening.
> >> Regards
> >> *Lene Fischer*
> >> Associate Professor
> >> MOB +45 40115084
> >> lfi at ign.ku.dk <mailto:lfi at ign.ku.dk <lfi at ign.ku.dk>>
> >> SCIENCE_bomaerke_UK
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Cheers Simon
> >      Simon Cropper - Open Content Creator
> >      Free and Open Source Software Workflow Guides
> >      Introduction               http://www.fossworkflowguides.com
> >      GIS Packages           http://www.fossworkflowguides.com/gis
> >      bash / Python    http://www.fossworkflowguides.com/scripting
> Cheers Simon
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140711/9f38f397/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140711/9f38f397/attachment.jpg>
