[Qgis-user] Splitting file into multiple csv files
Matt Boyd
mattslists at gmail.com
Mon Jul 14 18:26:47 PDT 2014
It's in csv so I can probably just script something in with awk or bash.
I'm a bit rustyon those.
On Tue, Jul 15, 2014 at 11:25 AM, Matt Boyd <mattslists at gmail.com> wrote:
> It needs a script, I haven't counted the lines but the csv file I used for
> the input is ~60mb.
> On Tue, Jul 15, 2014 at 10:24 AM, Mike Treglia <mtreglia at gmail.com> wrote:
>> How many groups do you have in that field? I.e., Is it reasonable to do a
>> process by hand a few times? Or is it an unreasonably large number of
>> groups in that field, where you'll really need to script it?
>> On Jul 14, 2014, at 6:52 PM, Matt Boyd <mattslists at gmail.com> wrote:
>> Hi fellow QGIS users.
>> I've got a rather large shapefile of point data, the points have a common
>> identifier field that I'd like to use to split each of the features out on.
>> In short: input data single file to output data (multiple files based on
>> column).
>> Is there a plugin that would do this or is it something I'd need to
>> script using gdal? I need to output in csv as well.
>> Thanks for any tips
>> Matt
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140715/6346ad83/attachment.html>
