[Qgis-user] Splitting file into multiple csv files
Mike Treglia
mtreglia at gmail.com
Mon Jul 14 18:38:09 PDT 2014
Well that's a pretty giant CSV :-)
I have no experience scripting in Q... I would have to do it in R myself, which would probably be pretty slow on a job like that...
Good luck! Hope somebody else had some thoughts
> On Jul 14, 2014, at 8:26 PM, Matt Boyd <mattslists at gmail.com> wrote:
> It's in csv so I can probably just script something in with awk or bash. I'm a bit rustyon those.
>> On Tue, Jul 15, 2014 at 11:25 AM, Matt Boyd <mattslists at gmail.com> wrote:
>> It needs a script, I haven't counted the lines but the csv file I used for the input is ~60mb.
>>> On Tue, Jul 15, 2014 at 10:24 AM, Mike Treglia <mtreglia at gmail.com> wrote:
>>> How many groups do you have in that field? I.e., Is it reasonable to do a process by hand a few times? Or is it an unreasonably large number of groups in that field, where you'll really need to script it?
>>>> On Jul 14, 2014, at 6:52 PM, Matt Boyd <mattslists at gmail.com> wrote:
>>>> Hi fellow QGIS users.
>>>> I've got a rather large shapefile of point data, the points have a common identifier field that I'd like to use to split each of the features out on.
>>>> In short: input data single file to output data (multiple files based on column).
>>>> Is there a plugin that would do this or is it something I'd need to script using gdal? I need to output in csv as well.
>>>> Thanks for any tips
>>>> Matt
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140714/4b90556d/attachment.html>
