[Qgis-user] Splitting file into multiple csv files
Zoltan Szecsei zoltans at geograph.co.za
Tue Jul 15 00:13:44 PDT 2014
Yep, thanks for the confirmation.
My next point (should awk close its files only after close of relevant
braces) was get everyone following this thread, to be wary their data
and the resulting number simultaneously open files that might be required.
As you say, "simple enough" (but if you don't think it through,
embarrassing results could be hidden in your (large dataset) results.
Cheers for now,
Zoltan
On 2014/07/15 09:08, Matt Boyd wrote:
> Hi Zoltan,
> good point. I did a little reading and there were some notes about awk
> / linux having issues if there were too many files open at one time so
> my assumption is that all files are open until the script finishes. My
> file was sorted and it appears to have worked, but as I go through the
> data I'll keep this in mind. I'll run it with >> to see if there is a
> difference tomorrow.
> regards
> Matt
> On Tue, Jul 15, 2014 at 4:47 PM, Zoltan Szecsei
> <zoltans at geograph.co.za <mailto:zoltans at geograph.co.za>> wrote:
>     Hi,
>     Can't test this now, and am a very novice awk user, but if column
>     3 was _not_ sorted, would only the last contiguous set of records
>     be in the output file(s)?
>     In other words, when does awk close the output file, and would
>     '>>' be safer than '>' ?
>     Regards,
>     Zoltan
>     On 2014/07/15 08:29, Matt Boyd wrote:
>>     I possibly shouldn't have bothered the list but as I did, this is
>>     the script I used.
>>     awk -F, '{print > $3}' Filtered_data.csv
>>     prints the whole line and creates a new file named & based on
>>     column 3.
>>     Simple enough to be embarrassing
>     Zoltan Szecsei PrGISc [PGP0031]
>     Geograph (Pty) Ltd.
>     GIS and Photogrammetric Services
>     P.O. Box 7, Muizenberg 7950, South Africa.
>     Mobile:+27-83-6004028  <tel:%2B27-83-6004028>
>     Fax:+27-86-6115323  <tel:%2B27-86-6115323>      www.geograph.co.za  <http://www.geograph.co.za>
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
Geograph (Pty) Ltd.
Mobile: +27-83-6004028
Fax:    +27-86-6115323     www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140715/56446249/attachment.html>
