[Qgis-user] Splitting file into multiple csv files
Matt Boyd
mattslists at gmail.com
Tue Jul 15 00:08:08 PDT 2014
Hi Zoltan,
good point. I did a little reading and there were some notes about awk /
linux having issues if there were too many files open at one time so my
assumption is that all files are open until the script finishes. My file
was sorted and it appears to have worked, but as I go through the data I'll
keep this in mind. I'll run it with >> to see if there is a difference
tomorrow.
regards
Matt
On Tue, Jul 15, 2014 at 4:47 PM, Zoltan Szecsei <zoltans at geograph.co.za>
wrote:
> Hi,
> Can't test this now, and am a very novice awk user, but if column 3 was
> *not* sorted, would only the last contiguous set of records be in the
> output file(s)?
> In other words, when does awk close the output file, and would '>>' be
> safer than '>' ?
> Regards,
> Zoltan
> On 2014/07/15 08:29, Matt Boyd wrote:
> I possibly shouldn't have bothered the list but as I did, this is the
> script I used.
> awk -F, '{print > $3}' Filtered_data.csv
> prints the whole line and creates a new file named & based on column 3.
> Simple enough to be embarrassing
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028
> Fax: +27-86-6115323 www.geograph.co.za
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140715/79a15268/attachment.html>
