[Qgis-user] Decimal numbers in Qgis
Hakala Oiva (MTT)
oiva.hakala at mtt.fi
Tue Jul 22 23:09:29 PDT 2014
Thanks Werner. It is possible to send a shapefile, but the problem is not tied with any specific shapefile. The problem is with every shapefile. And if I remember right there was also a problem with ArcGrid. All the grid values turned also to integers.
I will send the shapefile privately in a separate mail.
Oiva
________________________________________
Lähettäjä: Werner Macho [werner.macho at gmail.com]
Lähetetty: 23. heinäkuuta 2014 8:42
Vastaanottaja: Hakala Oiva (MTT)
Kopio: qgis-user at lists.osgeo.org
Aihe: Re: [Qgis-user] Decimal numbers in Qgis
Hi!
Is it possible to provide the shapefile somewhere to take a closer look at it?
regards
Werner
On Wed, Jul 23, 2014 at 7:37 AM, Hakala Oiva (MTT) <oiva.hakala at mtt.fi> wrote:
> Hi
> I am new here, but in trouble with Qgis.
> I have a BAD problem with decimal numbers in shapefile attribute tables.
> My set:
> Ubuntu Linux 12.04
> Qgis 2.2
> Locale FI
> Example:
> The original number in attribute table is: 342,52189242800
> Using binary editor I can see, that the internal format in dbf-file is:
> 3.42521892428e+002
> And when I load the shapefile to Qgis, the result is: 3.00000000000
> That is unaccepteble! In every attribute table all the digits beyond decimal
> separator are gone and the result is only integers.
> So, what to do? This kind of prevents me from doing any serious work with
> Qgis. I have never used any program before, that cannot handle decimals! I
> have tried to use different locale internally in Qgis (english), but no
> help.
> Oiva
> Qgis-user mailing list
