[Qgis-user] Qgis crashes at exit
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Wed Jul 23 05:36:18 PDT 2014
Would you be able to provide some information:
- Installation method? Stand-alone or OSGeo4W?
- What type of data? Vector, raster, other OGC services?
- Do you have AV running in the background?
- Does QGIS simply become "Not Responding" or crashes with dump file?
- Are the files located on a network drive or local disk?
- Can you run QGIS with no-plugin option see if it crashes upon opening
files?
Thanks,
Saber
-----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Bernd Vogelgesang
Sent: 23 July 2014 11:09
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Qgis crashes at exit
Same symptoms here with exactly same setup.
Before installing 2.4, I uninstalled and erased all traces of QGIS from the
system, so there should not have been any leftovers from old install.
Am 23.07.2014 09:02, schrieb AlpImage:
> Hi,
> my problem is that qgis *_always_* crashes when I try to exit from the
> program, both with 'File->Chiudi' and with the 'X' on top right, writing
> a 'file.dump' (I can send one of them gzipped, if useful).
> I tried to uninstall all the plugins but with no effects.
> Configuration: win 7 pro, qgis 2.4.0 64 bit:
> I also have Python 3.4 installed (the python files in win\system are
> those of the 3.4 distribution.)
> Same qgis installed on iMac has no problems.
> It's not a great problem (everything else is ok), but.
> Thanks and have a good day,
> *Emanuele Spando*
> /AlpImage Photo/
> 13900 BIELLA BI
> ITALIA
> _e.spando (at) alpimage.it_
> Qgis-user mailing list
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
