[Qgis-user] Opening Raster from ESRI .GDB
Alex Mandel
tech_dev at wildintellect.com
Thu Jul 24 13:04:00 PDT 2014
Sorta, there are 2 drivers for GDB. The open GDB that Even has been
working on and the official ESRI GDB api.
The ESRI GDB api and Arc instance are not backwards compatible, once you
upgrade a gdb to the latest it only works with the latest and there's
often no way to write an older variant.
The open GDB driver I think allows you to read any version and write
older versions if you need to without auto-upgrading.
Back to your original question does the ESRI gdb driver work for you use
case for now? On windows I think you can get it with OSGeo4w on Linux
you need to download the SDK from ESRI and recompile GDAL - but I don't
know if this is vector and raster or just vector.
Thanks,
Alex
On 07/24/2014 12:56 PM, Michael Treglia wrote:
> Hi Even,
> Thanks a lot for the quick response - I really appreciate your work in
> dealing with the GDB files!
> That sounds great! Let me know if you need more data examples and such.
> Just a quick question - .gdb is not typically forward and backward
> compatible across Arc versions, right? [I've definitely had .gdb files that
> don't work in QGIS, while some do, so I have assumed that it was due to
> versioning issues - is that right? Or should I be doing some
> trouble-shooting?]
> Thanks again, and best regards,
> Mike
> On Thu, Jul 24, 2014 at 3:27 PM, Even Rouault <even.rouault at mines-paris.org>
> wrote:
>> Le jeudi 24 juillet 2014 18:19:14, Michael Treglia a écrit :
>>> Hi All,
>>> I've Googled around, and it seems like this isn't currently possible, but
>>> wanted to check with folks on this list for any solution...
>>> A lot of data being produced by agencies is now available only as ESRI
>> .gdb
>>> files. A dataset I'm particularly interested in working with is a gridded
>>> soil dataset (
>> http://www.nrcs.usda.gov/wps/portal/nrcs/detail/soils/ref/?cid=nrcs142p2_05
>>> 3628 )
>>> These particular data are in raster format, stored as Arc 10.1 .gdb,
>>> available from here: http://datagateway.nrcs.usda.gov/GDGOrder.aspx
>> Mike,
>> When I reverse-engineered the vector part of FileGDB format that lead to
>> the
>> OGR OpenFileGDB driver of GDAL 1.11, I came through a few raster GDB
>> samples.
>> Dealing with them was not in the scope of the work that was funded, but
>> from
>> what I've seen, I've good hope that decoding them would be reachable. Would
>> need some extra investigation of course to confirm and complementary
>> funding...
>> Best regards,
>> Even
>>> Any suggestions are appreciated.
>>> Thanks!
>>> Mike
>> Geospatial professional services
>> http://even.rouault.free.fr/services.html
> Qgis-user mailing list
