[Qgis-user] In QGIS 2.4 disappeared the setting of mode-identify
G. Allegri
giohappy at gmail.com
Mon Jul 28 14:04:27 PDT 2014
Mmm, is the identify tool available if you click on the group? It's not for
me.
The legend is the TOC, the layer tree...
Look at this: http://tinyurl.com/oxy3lyo
2014-07-28 22:58 GMT+02:00 Michael Treglia <mtreglia at gmail.com>:
> I just created a group of line- based vector layers and the Identify tool
> is available. What do you mean by the "Legend"? (If you mean the "Identify
> Results" pane, I just noticed that the "View" menu gets grayed out.
> mike
> On Mon, Jul 28, 2014 at 4:42 PM, G. Allegri <giohappy at gmail.com> wrote:
>> Have you tried to create a group and select it in the Legend? Identify is
>> not avaiable. I'm on a master build right now.
>> 2014-07-28 22:39 GMT+02:00 Michael Treglia <mtreglia at gmail.com>:
>> Hmm, weird - what's your setup? I'm on QGIS 2.4, and its working fine for
>>> me on both 64 and 32 bit installs, on Win7 x64
>>> On Mon, Jul 28, 2014 at 4:33 PM, G. Allegri <giohappy at gmail.com> wrote:
>>>> Identify is greyed until a layer isn't selected. It means the "mode"
>>>> cannot be set inside the pane (because identify isn't available) if a group
>>>> is selected instead of a layer in the TOC. If you confirm this I consider
>>>> it a bug.
>>>> giovanni
>>>> 2014-07-28 22:30 GMT+02:00 Michael Treglia <mtreglia at gmail.com>:
>>>> In 2.4 for me, it is in the bottom of the window/pane that pops up when
>>>>> I select the identify tool, as "mode"
>>>>> Hope that helps,
>>>>> mike
>>>>> On Mon, Jul 28, 2014 at 4:15 PM, Andrea Peri <aperi2007 at gmail.com>
>>>>> wrote:
>>>>>> Hi,
>>>>>> In the qgis 2.2 in option->map tools there was the option to set
>>>>>> the mode of identify (current/topdown stop first/layer selection)
>>>>>> In the qgis 2.4 this setting in not available in the same place.
>>>>>> Is it move to another position ?
>>>>>> Thx.
>>>>>> Andrea Peri
>>>>>> qwerty àèìòù
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Giovanni Allegri
>>>> http://about.me/giovanniallegri
>>>> Twitter: https://twitter.com/_giohappy_
>>>> blog: http://blog.spaziogis.it
>>>> GEO+ geomatica in Italia http://bit.ly/GEOplus
>> Giovanni Allegri
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140728/438b8c1c/attachment.html>
