[Qgis-user] In QGIS 2.4 disappeared the setting of mode-identify
Michael Treglia
mtreglia at gmail.com
Mon Jul 28 14:14:21 PDT 2014
Yup - working fine for me: http://i.imgur.com/maGMi7c.png
On Mon, Jul 28, 2014 at 5:04 PM, G. Allegri <giohappy at gmail.com> wrote:
> Mmm, is the identify tool available if you click on the group? It's not
> for me.
> The legend is the TOC, the layer tree...
> Look at this: http://tinyurl.com/oxy3lyo
> 2014-07-28 22:58 GMT+02:00 Michael Treglia <mtreglia at gmail.com>:
> I just created a group of line- based vector layers and the Identify tool
>> is available. What do you mean by the "Legend"? (If you mean the "Identify
>> Results" pane, I just noticed that the "View" menu gets grayed out.
>> mike
>> On Mon, Jul 28, 2014 at 4:42 PM, G. Allegri <giohappy at gmail.com> wrote:
>>> Have you tried to create a group and select it in the Legend? Identify
>>> is not avaiable. I'm on a master build right now.
>>> 2014-07-28 22:39 GMT+02:00 Michael Treglia <mtreglia at gmail.com>:
>>> Hmm, weird - what's your setup? I'm on QGIS 2.4, and its working fine
>>>> for me on both 64 and 32 bit installs, on Win7 x64
>>>> On Mon, Jul 28, 2014 at 4:33 PM, G. Allegri <giohappy at gmail.com> wrote:
>>>>> Identify is greyed until a layer isn't selected. It means the "mode"
>>>>> cannot be set inside the pane (because identify isn't available) if a group
>>>>> is selected instead of a layer in the TOC. If you confirm this I consider
>>>>> it a bug.
>>>>> giovanni
>>>>> 2014-07-28 22:30 GMT+02:00 Michael Treglia <mtreglia at gmail.com>:
>>>>> In 2.4 for me, it is in the bottom of the window/pane that pops up
>>>>>> when I select the identify tool, as "mode"
>>>>>> Hope that helps,
>>>>>> mike
>>>>>> On Mon, Jul 28, 2014 at 4:15 PM, Andrea Peri <aperi2007 at gmail.com>
>>>>>> wrote:
>>>>>>> Hi,
>>>>>>> In the qgis 2.2 in option->map tools there was the option to set
>>>>>>> the mode of identify (current/topdown stop first/layer selection)
>>>>>>> In the qgis 2.4 this setting in not available in the same place.
>>>>>>> Is it move to another position ?
>>>>>>> Thx.
>>>>>>> Andrea Peri
>>>>>>> qwerty àèìòù
>>>>>>> _______________________________________________
>>>>>>> Qgis-user mailing list
>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Giovanni Allegri
>>>>> http://about.me/giovanniallegri
>>>>> Twitter: https://twitter.com/_giohappy_
>>>>> blog: http://blog.spaziogis.it
>>>>> GEO+ geomatica in Italia http://bit.ly/GEOplus
>>> Giovanni Allegri
> Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140728/65061cb1/attachment.html>
