[Qgis-user] In QGIS 2.4 disappeared the setting of mode-identify
G. Allegri giohappy at gmail.com
Mon Jul 28 14:22:13 PDT 2014
Werid. I will investigate it...
2014-07-28 23:14 GMT+02:00 Michael Treglia <mtreglia at gmail.com>:
> Yup - working fine for me: http://i.imgur.com/maGMi7c.png
> On Mon, Jul 28, 2014 at 5:04 PM, G. Allegri <giohappy at gmail.com> wrote:
>> Mmm, is the identify tool available if you click on the group? It's not
>> for me.
>> The legend is the TOC, the layer tree...
>> Look at this: http://tinyurl.com/oxy3lyo
>> 2014-07-28 22:58 GMT+02:00 Michael Treglia <mtreglia at gmail.com>:
>> I just created a group of line- based vector layers and the Identify tool
>>> is available.  What do you mean by the "Legend"? (If you mean the "Identify
>>> Results" pane, I just noticed that the "View" menu gets grayed out.
>>> mike
>>> On Mon, Jul 28, 2014 at 4:42 PM, G. Allegri <giohappy at gmail.com> wrote:
>>>> Have you tried to create a group and select it in the Legend? Identify
>>>> is not avaiable. I'm on a master build right now.
>>>> 2014-07-28 22:39 GMT+02:00 Michael Treglia <mtreglia at gmail.com>:
>>>> Hmm, weird - what's your setup? I'm on QGIS 2.4, and its working fine
>>>>> for me on both 64 and 32 bit installs, on Win7 x64
>>>>> On Mon, Jul 28, 2014 at 4:33 PM, G. Allegri <giohappy at gmail.com>
>>>>> wrote:
>>>>>> Identify is greyed until a layer isn't selected. It means the "mode"
>>>>>> cannot be set inside the pane (because identify isn't available) if a group
>>>>>> is selected instead of a layer in the TOC. If you confirm this I consider
>>>>>> it a bug.
>>>>>> giovanni
>>>>>> 2014-07-28 22:30 GMT+02:00 Michael Treglia <mtreglia at gmail.com>:
>>>>>> In 2.4 for me, it is in the bottom of the window/pane that pops up
>>>>>>> when I select the identify tool, as "mode"
>>>>>>> Hope that helps,
>>>>>>> mike
>>>>>>> On Mon, Jul 28, 2014 at 4:15 PM, Andrea Peri <aperi2007 at gmail.com>
>>>>>>> wrote:
>>>>>>>> Hi,
>>>>>>>> In the qgis 2.2 in option->map tools there was the option to set
>>>>>>>> the mode of identify (current/topdown stop first/layer selection)
>>>>>>>> In the qgis 2.4 this setting in not available in the same place.
>>>>>>>> Is it move to another position ?
>>>>>>>> Thx.
>>>>>>>> Andrea Peri
>>>>>>>> qwerty àèìòù
>>>>>>>> _______________________________________________
>>>>>>>> Qgis-user mailing list
>>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Giovanni Allegri
>>>>>> http://about.me/giovanniallegri
>>>>>> Twitter: https://twitter.com/_giohappy_
>>>>>> blog: http://blog.spaziogis.it
>>>>>> GEO+ geomatica in Italia http://bit.ly/GEOplus
>>>> Giovanni Allegri
>> Giovanni Allegri
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140728/09317514/attachment.html>
