[Qgis-user] Making border lines disappear
Frank Sokolic sokolic at worldonline.co.za
Wed Jul 30 04:07:12 PDT 2014
Hi Jonathan,
I've been struggling with this too. Even if you set Border Width to zero the borders are faintly visible. I hack I've used occasionally is to dissolve the polygons using whatever attribute you're categorising by but this is a far from ideal solution.
Frank.
Sent: 2014/07/30 12:53:25 PM
To: qgis-user at lists.osgeo.org
Cc:
Subject: RE: [Qgis-user] Making border lines disappear Hi List,Using 2.4, how do you make borders on polygons invisible? Apparently this worked fine in 2.2, but doesn't seem to be possible with 2.4.
Using the standard Simple Fill.
Border style: No Pen:
Border Style: Solid Line; Border: Dark green (second across from the Black) (fill: Same dark green):
If you look closely you'll see white lines.
Anyone else seeing this? It was brought up by one of our more observant users.
Cheers,Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140730/ce3ffb1d/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140730/ce3ffb1d/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140730/ce3ffb1d/attachment-0001.png>
