[Qgis-user] Making border lines disappear
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Jul 30 07:18:41 PDT 2014
Hi Frank,
Thanks for confirming. Dissolving was the plan that the user was going to
end up trying.
For those interested, it's on the tracker as:
http://hub.qgis.org/issues/10984
Cheers,
Jonathan
On 30 July 2014 12:07, Frank Sokolic <sokolic at worldonline.co.za> wrote:
> Hi Jonathan,
> I've been struggling with this too. Even if you set Border Width to zero
> the borders are faintly visible. I hack I've used occasionally is to
> dissolve the polygons using whatever attribute you're categorising by but
> this is a far from ideal solution.
> Frank.
> *From:* jonathanmoules at warwickshire.gov.uk
> *Sent:* 2014/07/30 12:53:25 PM
> *To:* qgis-user at lists.osgeo.org
> *Cc:*
> *Subject:* RE: [Qgis-user] Making border lines disappear
> Hi List,
> Using 2.4, how do you make borders on polygons invisible? Apparently this
> worked fine in 2.2, but doesn't seem to be possible with 2.4.
> Using the standard Simple Fill.
> Border style: No Pen:
> [image: Inline images 1]
> Border Style: Solid Line; Border: Dark green (second across from the
> Black) (fill: Same dark green):
> [image: Inline images 2]
> If you look closely you'll see white lines.
> Anyone else seeing this? It was brought up by one of our more observant
> users.
> Cheers,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain confidential, sensitive or personal information and should be
> handled accordingly. Unless you are the named addressee (or authorised to
> receive it for the addressee) you may not copy or use it, or disclose it to
> anyone else. If you have received this transmission in error please notify
> the sender immediately. All email traffic sent to or from us, including
> without limitation all GCSX traffic, may be subject to recording and/or
> monitoring in accordance with relevant legislation.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140730/e7b23c40/attachment.html>
