[Qgis-user] Making border lines disappear
Andreas Neumann a.neumann at carto.net
Wed Jul 30 07:27:39 PDT 2014
This is an anti aliasing issue that many rendering libraries have. I
doubt there is much the QGIS developers can do. It is beyond the control
of the QGIS developers and an upstream problem of the rendering in the
qt-library.
The AGG rendering library solved this issue: see
http://www.antigrain.com/screenshots/ and search for "adjacent polygons"
in the text.
I will forward this to the QGIS developers list.
Andreas
Am 30.07.2014 14:18, schrieb Jonathan Moules:
> Hi Frank,
> Thanks for confirming. Dissolving was the plan that the user was going
> to end up trying.
> For those interested, it's on the tracker as:
> http://hub.qgis.org/issues/10984
> Cheers,
> Jonathan
> On 30 July 2014 12:07, Frank Sokolic <sokolic at worldonline.co.za
> <mailto:sokolic at worldonline.co.za>> wrote:
>     Hi Jonathan,
>     I've been struggling with this too. Even if you set Border Width to
>     zero the borders are faintly visible. I hack I've used occasionally
>     is to dissolve the polygons using whatever attribute you're
>     categorising by but this is a far from ideal solution.
>     Frank.
>     *From:* jonathanmoules at warwickshire.gov.uk
>     <mailto:jonathanmoules at warwickshire.gov.uk>
>     *Sent:* 2014/07/30 12:53:25 PM
>     *To:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
>     *Cc:*
>     *Subject:* RE: [Qgis-user] Making border lines disappear
>     Hi List,
>     Using 2.4, how do you make borders on polygons invisible? Apparently
>     this worked fine in 2.2, but doesn't seem to be possible with 2.4.
>     Using the standard Simple Fill.
>     Border style: No Pen:
>     Inline images 1
>     Border Style: Solid Line; Border: Dark green (second across from the
>     Black) (fill: Same dark green):
>     Inline images 2
>     If you look closely you'll see white lines.
>     Anyone else seeing this? It was brought up by one of our more
>     observant users.
>     Cheers,
>     Jonathan
>     This transmission is intended for the named addressee(s) only and
>     may contain confidential, sensitive or personal information and
>     should be handled accordingly. Unless you are the named addressee
>     (or authorised to receive it for the addressee) you may not copy or
>     use it, or disclose it to anyone else. If you have received this
>     transmission in error please notify the sender immediately. All
>     email traffic sent to or from us, including without limitation all
>     GCSX traffic, may be subject to recording and/or monitoring in
>     accordance with relevant legislation.
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
> This transmission is intended for the named addressee(s) only and may
> contain confidential, sensitive or personal information and should be
> handled accordingly. Unless you are the named addressee (or authorised
> to receive it for the addressee) you may not copy or use it, or disclose
> it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from
> us, including without limitation all GCSX traffic, may be subject to
> recording and/or monitoring in accordance with relevant legislation.
