[Qgis-user] Making border lines disappear
Alexandre Neto
senhor.neto at gmail.com
Wed Jul 30 12:39:43 PDT 2014
A simple workaround (until it get fixed) could be to had a very thin border
of the same colour/transparency of the fill.
Alexandre Neto
Em 30/07/2014 15:27, "Andreas Neumann" <a.neumann at carto.net> escreveu:
> Hi,
> This is an anti aliasing issue that many rendering libraries have. I
> doubt there is much the QGIS developers can do. It is beyond the control
> of the QGIS developers and an upstream problem of the rendering in the
> qt-library.
> The AGG rendering library solved this issue: see
> http://www.antigrain.com/screenshots/ and search for "adjacent polygons"
> in the text.
> I will forward this to the QGIS developers list.
> Andreas
> Am 30.07.2014 14:18, schrieb Jonathan Moules:
> > Hi Frank,
> > Thanks for confirming. Dissolving was the plan that the user was going
> > to end up trying.
> > For those interested, it's on the tracker as:
> > http://hub.qgis.org/issues/10984
> > Cheers,
> > Jonathan
> > On 30 July 2014 12:07, Frank Sokolic <sokolic at worldonline.co.za
> > <mailto:sokolic at worldonline.co.za>> wrote:
> > Hi Jonathan,
> > I've been struggling with this too. Even if you set Border Width to
> > zero the borders are faintly visible. I hack I've used occasionally
> > is to dissolve the polygons using whatever attribute you're
> > categorising by but this is a far from ideal solution.
> > Frank.
> > *From:* jonathanmoules at warwickshire.gov.uk
> > <mailto:jonathanmoules at warwickshire.gov.uk>
> > *Sent:* 2014/07/30 12:53:25 PM
> > *To:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> > *Cc:*
> > *Subject:* RE: [Qgis-user] Making border lines disappear
> > Hi List,
> > Using 2.4, how do you make borders on polygons invisible? Apparently
> > this worked fine in 2.2, but doesn't seem to be possible with 2.4.
> > Using the standard Simple Fill.
> > Border style: No Pen:
> > Inline images 1
> > Border Style: Solid Line; Border: Dark green (second across from the
> > Black) (fill: Same dark green):
> > Inline images 2
> > If you look closely you'll see white lines.
> > Anyone else seeing this? It was brought up by one of our more
> > observant users.
> > Cheers,
> > Jonathan
> > This transmission is intended for the named addressee(s) only and
> > may contain confidential, sensitive or personal information and
> > should be handled accordingly. Unless you are the named addressee
> > (or authorised to receive it for the addressee) you may not copy or
> > use it, or disclose it to anyone else. If you have received this
> > transmission in error please notify the sender immediately. All
> > email traffic sent to or from us, including without limitation all
> > GCSX traffic, may be subject to recording and/or monitoring in
> > accordance with relevant legislation.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > This transmission is intended for the named addressee(s) only and may
> > contain confidential, sensitive or personal information and should be
> > handled accordingly. Unless you are the named addressee (or authorised
> > to receive it for the addressee) you may not copy or use it, or disclose
> > it to anyone else. If you have received this transmission in error
> > please notify the sender immediately. All email traffic sent to or from
> > us, including without limitation all GCSX traffic, may be subject to
> > recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140730/0c810bdd/attachment.html>
