[Qgis-user] Time manager 1.1 in QGIS 2.4
Anita Graser anitagraser at gmx.at
Sun Jun 29 08:28:04 PDT 2014
Thanks. I can now reproduce the issue. It was caused by one of the
latest changes to fix DATE type support
https://github.com/anitagraser/TimeManager/commit/926fa544bb6a993c41f4dcfc532fa2568c883949
Best wishes,
Anita
On Sun, Jun 29, 2014 at 4:10 PM, G. Garibaldi <digitalmaps at cox.net> wrote:
> Same non-functional result on OSGeo4W installer. TM animation works properly
> with shape file data. Looks like the problem is with the PostgreSQL database
> connection. Permissions would be my guess.
> I'll have to export all my point data to shape files to do animation. Hey,
> its free.
> The QGIS 2.4 release is fast.
> Thanks Anita, everybody.
> G.
> Windows 7 64-bit. QGIS standalone installer. Time Manager version 1.1. I
> start a new project, load one vector layer of a PostgreSQL database table
> with point data. PostgreSQL version 9.3, PostGIS version 2.1. The data shows
> on screen. Open TM dialog and select the layer as usual. Up to this point
> everything functions as expected. The screen looks normal. When I enable TM
> the data disappears. I check the time, looks OK. Time interval is correct.
> Opening the attribute table while TM is enabled shows no datapoints when I
> expect one data point. When I disable TM all the data reappears.
> Using TM 1.0 enables me to load layers that do function normally, however
> when I save the project, exit and then restart the project only one layer
> shows in the layer list in TM. The other layers don't get saved.
> This is an old project that works well enough in QGIS 1.8. with TM 0.7. In
> later versions I can't get TM to function properly.
> I'll try the OSGeo4W installer.
> Hi,
> I get the same deprecation warning but it does not affect the
> functioning of the plugin for me with 2.4 installed using OSGeo4W
> 64bit installer on Win8.
> Could you describe a bit more what happens? Is the whole screen blank?
> Or is just the TimeManager panel blank? Which OS?
> Best wishes,
> Anita
> On Sun, Jun 29, 2014 at 8:22 AM, G. Garibaldi <digitalmaps at cox.net> wrote:
> I can't get TM 1.1 to work in 2.4 64-bit. Load one layer and it doesn't show
> anything when TM is enabled - blank screen. Interestingly, TM 1.0 works
> somewhat.
> Log File:
> warning:C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\uiparser.py:844:
> PendingDeprecationWarning: This method will be removed in future versions.
> Use 'elem.iter()' or 'list(elem.iter())' instead.
>   for include in elem.getiterator("include"):
> traceback:  File "<string>", line 1, in <module>
>   File "C:/PROGRA~1/QGISCH~1/apps/qgis/./python\qgis\utils.py", line 213, in
> startPlugin
>     plugins[packageName].initGui()
>   File
> "C:/Users/Garibaldi/.qgis2/python/plugins\timemanager\timemanager.py", line
> 44, in initGui
>     control.initGui()
>   File
> "C:/Users/Garibaldi/.qgis2/python/plugins\timemanager\timemanagercontrol.py",
> line 65, in initGui
>     self.guiControl =
> TimeManagerGuiControl(self.iface,self.timeLayerManager)
>   File
> "C:/Users/Garibaldi/.qgis2/python/plugins\timemanager\timemanagerguicontrol.py",
> line 54, in __init__
>     self.dock = uic.loadUi( os.path.join( path, "dockwidget2.ui" ) )
>   File
> "C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\__init__.py",
> line 238, in loadUi
>     return DynamicUILoader(package).loadUi(uifile, baseinstance,
> resource_suffix)
>   File
> "C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\Loader\loader.py",
> line 71, in loadUi
>     return self.parse(filename, resource_suffix, basedir)
>   File
> "C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\uiparser.py",
> line 933, in parse
>     actor(elem)
>   File
> line 844, in readResources
> Qgis-user mailing list
