[Qgis-user] Time manager 1.1 in QGIS 2.4
    Anita Graser
    anitagraser at gmx.at
    Sun Jun 29 09:04:13 PDT 2014
PostGIS layers should work again
https://github.com/anitagraser/TimeManager/commit/2d7b769d8937a405c105041f307619c9c58ed62e
Try http://plugins.qgis.org/plugins/timemanager/version/1.1.2/
Thanks for reporting this issue!
On Sun, Jun 29, 2014 at 5:28 PM, Anita Graser <anitagraser at gmx.at> wrote:
> Thanks. I can now reproduce the issue. It was caused by one of the
> latest changes to fix DATE type support
> https://github.com/anitagraser/TimeManager/commit/926fa544bb6a993c41f4dcfc532fa2568c883949
> Best wishes,
> Anita
> On Sun, Jun 29, 2014 at 4:10 PM, G. Garibaldi <digitalmaps at cox.net> wrote:
>> Same non-functional result on OSGeo4W installer. TM animation works properly
>> with shape file data. Looks like the problem is with the PostgreSQL database
>> connection. Permissions would be my guess.
>> I'll have to export all my point data to shape files to do animation. Hey,
>> its free.
>> The QGIS 2.4 release is fast.
>> Thanks Anita, everybody.
>> G.
>> Windows 7 64-bit. QGIS standalone installer. Time Manager version 1.1. I
>> start a new project, load one vector layer of a PostgreSQL database table
>> with point data. PostgreSQL version 9.3, PostGIS version 2.1. The data shows
>> on screen. Open TM dialog and select the layer as usual. Up to this point
>> everything functions as expected. The screen looks normal. When I enable TM
>> the data disappears. I check the time, looks OK. Time interval is correct.
>> Opening the attribute table while TM is enabled shows no datapoints when I
>> expect one data point. When I disable TM all the data reappears.
>> Using TM 1.0 enables me to load layers that do function normally, however
>> when I save the project, exit and then restart the project only one layer
>> shows in the layer list in TM. The other layers don't get saved.
>> This is an old project that works well enough in QGIS 1.8. with TM 0.7. In
>> later versions I can't get TM to function properly.
>> I'll try the OSGeo4W installer.
>> Hi,
>> I get the same deprecation warning but it does not affect the
>> functioning of the plugin for me with 2.4 installed using OSGeo4W
>> 64bit installer on Win8.
>> Could you describe a bit more what happens? Is the whole screen blank?
>> Or is just the TimeManager panel blank? Which OS?
>> Best wishes,
>> Anita
>> On Sun, Jun 29, 2014 at 8:22 AM, G. Garibaldi <digitalmaps at cox.net> wrote:
>> I can't get TM 1.1 to work in 2.4 64-bit. Load one layer and it doesn't show
>> anything when TM is enabled - blank screen. Interestingly, TM 1.0 works
>> somewhat.
>> Log File:
>> warning:C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\uiparser.py:844:
>> PendingDeprecationWarning: This method will be removed in future versions.
>> Use 'elem.iter()' or 'list(elem.iter())' instead.
>>   for include in elem.getiterator("include"):
>> traceback:  File "<string>", line 1, in <module>
>>   File "C:/PROGRA~1/QGISCH~1/apps/qgis/./python\qgis\utils.py", line 213, in
>> startPlugin
>>     plugins[packageName].initGui()
>>   File
>> "C:/Users/Garibaldi/.qgis2/python/plugins\timemanager\timemanager.py", line
>> 44, in initGui
>>     control.initGui()
>>   File
>> "C:/Users/Garibaldi/.qgis2/python/plugins\timemanager\timemanagercontrol.py",
>> line 65, in initGui
>>     self.guiControl =
>> TimeManagerGuiControl(self.iface,self.timeLayerManager)
>>   File
>> "C:/Users/Garibaldi/.qgis2/python/plugins\timemanager\timemanagerguicontrol.py",
>> line 54, in __init__
>>     self.dock = uic.loadUi( os.path.join( path, "dockwidget2.ui" ) )
>>   File
>> "C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\__init__.py",
>> line 238, in loadUi
>>     return DynamicUILoader(package).loadUi(uifile, baseinstance,
>> resource_suffix)
>>   File
>> "C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\Loader\loader.py",
>> line 71, in loadUi
>>     return self.parse(filename, resource_suffix, basedir)
>>   File
>> "C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\uiparser.py",
>> line 933, in parse
>>     actor(elem)
>>   File
>> line 844, in readResources
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
