[Qgis-user] Relationships and SQL Spatial as Child
    James Wood
    jwood911 at gmail.com
    Sun Mar  2 08:43:22 PST 2014
Hello QGIS Users,Just wanted to know if anyone else has run into this... I'm running QGIS 2.2 x64 (OSGeo4W installer) on Windows 7 SP1. When trying to utilize the new Relations piece (which is a GREAT addition), I can establish relationships and have them work perfectly except when the child (or referencing layer) is in my SQL Express 2012 database. I set up a test project with identical address points and parcel layers in PostGIS, SpatiaLite and SQL. I can get any combination to work, but when the child layer is in the SQL db it will not. A picture is worth a thousand words, so I took some screenshots:      I've double-checked the linking ID field for the parcels and it is always a 1:1 with the address point I have identified. However, just to be sure it wasn't something funky with the parcel base, I established a link between the address points and an aed (defibrillator) point layer that I had with the same result. I also tried establishing a relationship with a non-geometry table in another db in the same instance without any luck.  I'll be interested in your feedback... Thanks,James
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140302/238ae914/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140302/238ae914/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140302/238ae914/attachment-0001.png>
