[Qgis-user] Relationships and SQL Spatial as Child
    James Wood
    jwood911 at gmail.com
    Fri Mar  7 07:24:21 PST 2014
Just wanted to float this one again to see if anyone had any feedback.
Thanks,
---------- Forwarded message ----------
Date: Sun, Mar 2, 2014 at 10:43 AM
Subject: Relationships and SQL Spatial as Child
To: QGIS-User Mailing List <qgis-user at lists.osgeo.org>
Hello QGIS Users,
Just wanted to know if anyone else has run into this...
I'm running QGIS 2.2 x64 (OSGeo4W installer) on Windows 7 SP1.
When trying to utilize the new Relations piece (which is a GREAT addition),
I can establish relationships and have them work perfectly except when the
child (or referencing layer) is in my SQL Express 2012 database. I set up a
test project with identical address points and parcel layers in PostGIS,
SpatiaLite and SQL. I can get any combination to work, but when the child
layer is in the SQL db it will not.
A picture is worth a thousand words, so I took some screenshots:
I've double-checked the linking ID field for the parcels and it is always a
1:1 with the address point I have identified. However, just to be sure it
wasn't something funky with the parcel base, I established a link between
the address points and an aed (defibrillator) point layer that I had with
the same result. I also tried establishing a relationship with a
non-geometry table in another db in the same instance without any luck.
I'll be interested in your feedback...
Thanks,
James
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140307/1f60e6ba/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140307/1f60e6ba/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140307/1f60e6ba/attachment-0001.png>
