[Qgis-user] QGIS Python integration
    Alex Mandel
    tech_dev at wildintellect.com
    Sun Mar  2 23:43:21 PST 2014
You likely have a package conflict by mixing repos.
Do you have both qgis.org and ubuntugis repos enabled?
Could also be from using "proposed" on ubuntu or backports.
QGIS reinstall will be likely need to be reinstalled once you get rid of
the conflicting package repos.
Thanks,
Alex
On 03/02/2014 11:17 PM, Derek Hohls wrote:
> I have a similar problem to Dave, but a different error:
> sudo apt-get install python-qgis
> Some packages could not be installed. This may mean that you have
> requested an impossible situation or if you are using the unstable
> distribution that some required packages have not yet been created
> or been moved out of Incoming.
> The following information may help to resolve the situation:
> The following packages have unmet dependencies:
> python-qgis : Depends: libqgis1.7.5 but it is not going to be installed
> E: Unable to correct problems, you have held broken packages.
> Is there a way to resolve this without reinstalling QGIS? (I am running
> Ubuntu 13.10)
> Thanks
> Derek
>>>> Alex Mandel <tech_dev at wildintellect.com> 03/01/14 4:30 AM >>>
> On 02/28/2014 04:19 PM, Dave Kimble wrote:
>> Ubuntu 13.10, QGIS 2.0.1, Python 2.7.5, Python 3.3.2
>> QGIS > Plugins > Manage Plugins > Settings > is saying "no python
>> support detected",
>> but I have v2.7 and v3.3 installed.
>> QGIS is working OK, but I guess I'm missing some features.
>> I need to clip some gigantic shapefiles down to just my locality, which
>> I think you call geoprocessing, and it looks like ftools will do that,
>> but it doesn't show up on the plug-in list.
>> How do you search the archives for previously asked questions?
> http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-f4099105.html
> The most likely answer is your missing the python-qgis package. FYI QGIS
> uses python 2.x
> Thanks,
> Alex
> Qgis-user mailing list
