[Qgis-user] google map connector
    Werner Macho
    werner.macho at gmail.com
    Mon Mar  3 04:32:27 PST 2014
Hi!
I think the same thing applies as for every plugin right now ..
If you are using master you should be aware that a lot of changes already
went into master (like multi-threaded-rendering) and some things changed so
that plugins must be adopted to follow this changes ..
As 2.3 is the "master" thing will not happen urgent .. You are on the
development branch ..
If you need plugins to work you should currently go "back" to 2.2 and look
from time to time if plugins are already changed. (Or go change the plugin
yourself and make a pull request)
In your case have you tried contacting the author of the plugin?
kind regards
Werner
On Mon, Mar 3, 2014 at 12:47 PM, Jake Maier <j.m at jmforestry.com> wrote:
> I installed the google map connector and get the following error when
> trying to authenticate.
> I use 2.3.0 Master on Windows 7 prof.
> Is this a bug or did I do anything wrong?
> Thanks for your help
> Jake
> [image: Google] <https://www.google.com/>
> *Error: invalid_client*
> Bad request.
> Request Details
>    - cookie_policy_enforce=false
>    - response_type=code
>    - scope=https://www.googleapis.com/auth/mapsengine
>    https://www.googleapis.com/auth/userinfo.profile
>    - redirect_uri=urn:ietf:wg:oauth:2.0:oob
>    - approval_prompt=auto
>    - state=123456789
>    - client_id=j.m at jmforestry.com
> Jake Maier
> 6 Lower Falls Road
> Orland
> ME 04472
> 469 0231
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140303/31f2ef4d/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140303/31f2ef4d/attachment.obj>
