[Qgis-user] google map connector
    Jake Maier
    j.m at jmforestry.com
    Mon Mar  3 15:05:26 PST 2014
Danke Werner
No I didn’t contact anybody but the list so far.
Yes, I will go back to 2.2 because that’s an important feature for me which I just discovered.
Now should I do anything else short of writing the plug-in myself. Don’t have the know-how.
I was not complaining at all. I am very happy with what the qgis team did and still is doing. It’s priceless not only for the gis community but beyond by giving an incredible example of what is possible parallel to the for profit world.
Thanks very much
Jake
From: Werner Macho [mailto:werner.macho at gmail.com]
Sent: Monday, March 03, 2014 7:32 AM
To: Jake Maier
Cc: qgis-user
Subject: Re: [Qgis-user] google map connector
Hi!
I think the same thing applies as for every plugin right now ..
If you are using master you should be aware that a lot of changes already went into master (like multi-threaded-rendering) and some things changed so that plugins must be adopted to follow this changes ..
As 2.3 is the "master" thing will not happen urgent .. You are on the development branch ..
If you need plugins to work you should currently go "back" to 2.2 and look from time to time if plugins are already changed. (Or go change the plugin yourself and make a pull request)
In your case have you tried contacting the author of the plugin?
kind regards
Werner
On Mon, Mar 3, 2014 at 12:47 PM, Jake Maier <j.m at jmforestry.com> wrote:
I installed the google map connector and get the following error when trying to authenticate.
I use 2.3.0 Master on Windows 7 prof.
Is this a bug or did I do anything wrong?
Thanks for your help
Jake
 <https://www.google.com/> Google
Error: invalid_client
Bad request.
Request Details
*	cookie_policy_enforce=false
*	response_type=code
*	scope=https://www.googleapis.com/auth/mapsengine https://www.googleapis.com/auth/userinfo.profile
*	redirect_uri=urn:ietf:wg:oauth:2.0:oob
*	approval_prompt=auto
*	state=123456789
*	client_id=j.m at jmforestry.com
Jake Maier
6 Lower Falls Road
Orland
ME 04472
469 0231
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140303/693a38bd/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140303/693a38bd/attachment.obj>
