[Qgis-user] Georeferencer problem with Qgis 2.2
    Jonathan Moules
    jonathanmoules at warwickshire.gov.uk
    Mon Mar  3 04:47:30 PST 2014
Yep, I'm getting this as well. Exact same behaviour.
QGIS 64-bit, Windows 7.
Is there a ticket for this?
Cheers,
Jonathan
On 22 February 2014 19:19, Gerardo Jiménez <gejst5 at gmail.com> wrote:
> Hi
> I just want to know if somebody else has the sma problem as me. I
> installed Qgis 2.2 64bits via OSGeo. When I try to use the georefencer, the
> main window appears, then stops responding, then I have a message saying
> "bad allocation" and then start responding. After that I can work with the
> georeferencer without a problem. I have the sam problem in 4 differen
> machines, all running win 7 64bits.
> Thanks before hand
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140303/8b2c3c83/attachment.html>
