[Qgis-user] QGIS process usage - benchmark
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Mon Mar 3 09:03:41 PST 2014
Hi Alen,
Can't you use the Python libraries to get that information?
For example for time there's:
http://docs.python.org/2/library/timeit.html or you can roll your own
fairly easily.
Or perhaps: https://pypi.python.org/pypi/benchmark/0.1.5 (not used it
myself).
I think using Python would be the best option.
Cheers,
Jonathan
On 28 February 2014 12:52, Alen Mangafic <amangaf at gmail.com> wrote:
> Hi,
> I am Alen, a student of Geodesy in the University of Ljubljana.
> In my diploma I am dealing with running geospatial Python scripts in QGIS
> and in the final
> part of it I would love to compare (qualitative and quantitative) the
> running of those scripts in the Linux and the Windows QGIS versions (same
> computer with the latest Linux distribution of the used version and latest
> Win OS,  latest updates, same QGIS version and without modifications).
> I would need a recommendation for a tool/method, for both platforms, which
> can evaluate the speed of a process, the amount of RAM being used and other
> data that are related with performance (QGIS/OS benchmark) so I can compare
> them.
> I would also like to hear from you which Linux OS do you recommend for
> this testing.
> I planned to use Debian Wheezy. Which Linux distribution do you recommend
> to perform my study?
> My goal is to use one, that will give the best results in performance
> (know it's difficult to tell, also "experience answers" are appreciated),
> cause one of my diploma goals is also to promote the using of Linux on my
> university for geodetic engineering purposes and I would like to show it in
> the best light possible.
> Thanks,
> Regards
> Alen
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140303/4a9b547f/attachment.html>
