[Qgis-user] QGIS - gdal
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Mar 3 23:50:13 PST 2014
Hi Matt,
Yes I did, no luck. I now also installed QGIS and gdal using the
ubuntugis ppa, and that works. But I still would like to get this to
work to be able to use/test the QGIS development version.
Paulo
On Tue 04 Mar 2014 04:08:30 AM CET, Matt Boyd wrote:
> Hi Paulo,
> I'm a little out of practice configuring gdal in linux, but I vaguely
> recall doing something like this a while ago, my apologies if this is
> a too obvious.
> Have you looked at the gdal tool settings in the raster menu of qgis?
> Matt
> On Mon, Mar 3, 2014 at 9:41 PM, Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
> Hi I am running QGIS master on Ubuntu 13.10. All runs fine, except
> for any function that relies on gdal (raster menu or the gdal
> functions in the processing toolbox). The functions work without
> problem on the command line, but QGIS cannot find gdal it seems.
> I compiled QGIS with the following gdal settings:
> * GDAL_CONFIG = /usr/local/gdal1.10/bin/gdal-config
> * GDAL_CONFIG_PREFER_FWTOOLS_PATH = /bin_safe
> * GDAL_CONFIG_PREFER_PATH = /bin
> * GDAL_INCLUDE_DIR = /usr/local/gdal1.10/include
> * GDAL_LIBRARY = /usr/local/gdal1.10/lib/libgdal.so
> I am actually not sure about the 2nd and 3rd. Are those settings
> correct?
> I compiled gdal 1.10 from source in /usr/local/gdal and tried all
> the following:
> * added a gdal.conf file with the gdal lib path in the
> etc/ld.so.conf.d folder (ran ldconfig)
> * created a softlink of the usr/local/gdal1.10/bin folder in
> /usr/bin
> * defined gdal paths in /home/paulo/.bashrc by adding the line:
> export PATH=$PATH:/usr/local/gdal1.10/bin
> * created executable file libraries.sh in /etc/profile.d with
> the lines
> o #!/bin/sh
> o LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/lib:/usr/local/lib:/usr/local/gdal1.10/lib"
> o export LD_LIBRARY_PATH
> Any idea what to do next?
> Paulo
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
