[Qgis-user] QGIS - gdal
Alex Mandel tech_dev at wildintellect.com
Mon Mar 3 23:54:37 PST 2014
I suspect its an ld path configuration issue. Similar to this but with GDAL
http://hub.qgis.org/issues/5859
Thanks,
Alex
On 03/03/2014 11:50 PM, Paulo van Breugel wrote:
> Hi Matt,
> Yes I did, no luck. I now also installed QGIS and gdal using the
> ubuntugis ppa, and that works. But I still would like to get this to
> work to be able to use/test the QGIS development version.
> Paulo
> On Tue 04 Mar 2014 04:08:30 AM CET, Matt Boyd wrote:
>> Hi Paulo,
>> I'm a little out of practice configuring gdal in linux, but I vaguely
>> recall doing something like this a while ago, my apologies if this is
>> a too obvious.
>> Have you looked at the gdal tool settings in the raster menu of qgis?
>> Matt
>> On Mon, Mar 3, 2014 at 9:41 PM, Paulo van Breugel
>> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
>>     Hi I am running QGIS master on Ubuntu 13.10. All runs fine, except
>>     for any function  that relies on gdal (raster menu or the gdal
>>     functions in the processing toolbox). The functions work without
>>     problem on the command line, but QGIS cannot find gdal it seems.
>>     I compiled QGIS with the following gdal settings:
>>       * GDAL_CONFIG = /usr/local/gdal1.10/bin/gdal-config
>>       * GDAL_CONFIG_PREFER_FWTOOLS_PATH = /bin_safe
>>       * GDAL_CONFIG_PREFER_PATH = /bin
>>       * GDAL_INCLUDE_DIR = /usr/local/gdal1.10/include
>>       * GDAL_LIBRARY = /usr/local/gdal1.10/lib/libgdal.so
>>     I am actually not sure about the 2nd and 3rd.  Are those settings
>>     correct?
>>     I compiled gdal 1.10 from source in /usr/local/gdal and tried all
>>     the following:
>>       * added a gdal.conf file with the gdal lib path in the
>>         etc/ld.so.conf.d folder (ran ldconfig)
>>       * created a softlink of the usr/local/gdal1.10/bin folder in
>>         /usr/bin
>>       * defined gdal paths in /home/paulo/.bashrc by adding the line:
>>         export PATH=$PATH:/usr/local/gdal1.10/bin
>>       * created executable file libraries.sh in /etc/profile.d with
>>         the lines
>>           o #!/bin/sh
>>           o
>> LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/lib:/usr/local/lib:/usr/local/gdal1.10/lib"
>>           o export LD_LIBRARY_PATH
>>     Any idea what to do next?
>>     Paulo
>>     _______________________________________________
>>     Qgis-user mailing list
>>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/qgis-user
