[Qgis-user] FW: google map connector
    Nathan Woodrow
    madmanwoo at gmail.com
    Tue Mar  4 03:58:14 PST 2014
Did you email him?
I have cc'd him in on the email.
- Nathan
On Tue, Mar 4, 2014 at 9:20 PM, Jake Maier <j.m at jmforestry.com> wrote:
> I re-installed the plug-in and went back to qgis 2.2  still I get the
> following error
> I also seem not able to contact the developer (Google)
> Any idea what I should do?
> J
> [image: Google] <https://www.google.com/>
> *Error: invalid_client*
> Bad request.
> Request Details
> *From:* Jake Maier [mailto:j.m at jmforestry.com]
> *Sent:* Monday, March 03, 2014 6:05 PM
> *To:* 'Werner Macho'
> *Cc:* 'qgis-user'
> *Subject:* RE: [Qgis-user] google map connector
> Danke Werner
> No I didn't contact anybody but the list so far.
> Yes, I will go back to 2.2 because that's an important feature for me
> which I just discovered.
> Now should I do anything else short of writing the plug-in myself. Don't
> have the know-how.
> I was not complaining at all. I am very happy with what the qgis team did
> and still is doing. It's priceless not only for the gis community but
> beyond by giving an incredible example of what is possible parallel to the
> for profit world.
> Thanks very much
> Jake
> *From:* Werner Macho [mailto:werner.macho at gmail.com<werner.macho at gmail.com>]
> *Sent:* Monday, March 03, 2014 7:32 AM
> *To:* Jake Maier
> *Cc:* qgis-user
> *Subject:* Re: [Qgis-user] google map connector
> Hi!
> I think the same thing applies as for every plugin right now ..
> If you are using master you should be aware that a lot of changes already
> went into master (like multi-threaded-rendering) and some things changed so
> that plugins must be adopted to follow this changes ..
> As 2.3 is the "master" thing will not happen urgent .. You are on the
> development branch ..
> If you need plugins to work you should currently go "back" to 2.2 and look
> from time to time if plugins are already changed. (Or go change the plugin
> yourself and make a pull request)
> In your case have you tried contacting the author of the plugin?
> kind regards
> Werner
> On Mon, Mar 3, 2014 at 12:47 PM, Jake Maier <j.m at jmforestry.com> wrote:
> I installed the google map connector and get the following error when
> trying to authenticate.
> I use 2.3.0 Master on Windows 7 prof.
> Is this a bug or did I do anything wrong?
> Thanks for your help
> Jake
> Bad request.
> Request Details
>    - cookie_policy_enforce=false
>    - response_type=code
>    - scope=https://www.googleapis.com/auth/mapsengine
>    https://www.googleapis.com/auth/userinfo.profile
>    - redirect_uri=urn:ietf:wg:oauth:2.0:oob
>    - approval_prompt=auto
>    - state=123456789
>    - client_id=j.m at jmforestry.com
> Jake Maier
> 6 Lower Falls Road
> Orland
> ME 04472
> 469 0231
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140304/8b56dc14/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140304/8b56dc14/attachment.obj>
