[Qgis-user] FW: google map connector
Ujaval Gandhi
ujaval at google.com
Tue Mar 4 06:15:54 PST 2014
Thanks Nathan.
Jake , this looks like a problem with your client id setup. You would need
to use client_id for Native Applications, verify in Cloud Console that you
are using the correct type of client id.
Also note that the connector works only with the platform edition of maps
engine (not lite or pro). Check that you are using the correct edition.If
you haven't signed up for google maps engine yet you can get a trial
account at https://mapsengine.google.com/projects/new
Feel free to email me directly if you still face problems setting it up.
-Ujaval
On Tue, Mar 4, 2014 at 5:28 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Did you email him?
> I have cc'd him in on the email.
> - Nathan
> On Tue, Mar 4, 2014 at 9:20 PM, Jake Maier <j.m at jmforestry.com> wrote:
>> I re-installed the plug-in and went back to qgis 2.2 still I get the
>> following error
>> I also seem not able to contact the developer (Google)
>> Any idea what I should do?
>> J
>> [image: Google] <https://www.google.com/>
>> *Error: invalid_client*
>> Bad request.
>> Request Details
>> *From:* Jake Maier [mailto:j.m at jmforestry.com]
>> *Sent:* Monday, March 03, 2014 6:05 PM
>> *To:* 'Werner Macho'
>> *Cc:* 'qgis-user'
>> *Subject:* RE: [Qgis-user] google map connector
>> Danke Werner
>> No I didn’t contact anybody but the list so far.
>> Yes, I will go back to 2.2 because that’s an important feature for me
>> which I just discovered.
>> Now should I do anything else short of writing the plug-in myself. Don’t
>> have the know-how.
>> I was not complaining at all. I am very happy with what the qgis team did
>> and still is doing. It’s priceless not only for the gis community but
>> beyond by giving an incredible example of what is possible parallel to the
>> for profit world.
>> Thanks very much
>> Jake
>> *From:* Werner Macho [mailto:werner.macho at gmail.com<werner.macho at gmail.com>]
>> *Sent:* Monday, March 03, 2014 7:32 AM
>> *To:* Jake Maier
>> *Cc:* qgis-user
>> *Subject:* Re: [Qgis-user] google map connector
>> Hi!
>> I think the same thing applies as for every plugin right now ..
>> If you are using master you should be aware that a lot of changes already
>> went into master (like multi-threaded-rendering) and some things changed so
>> that plugins must be adopted to follow this changes ..
>> As 2.3 is the "master" thing will not happen urgent .. You are on the
>> development branch ..
>> If you need plugins to work you should currently go "back" to 2.2 and
>> look from time to time if plugins are already changed. (Or go change the
>> plugin yourself and make a pull request)
>> In your case have you tried contacting the author of the plugin?
>> kind regards
>> Werner
>> On Mon, Mar 3, 2014 at 12:47 PM, Jake Maier <j.m at jmforestry.com> wrote:
>> I installed the google map connector and get the following error when
>> trying to authenticate.
>> I use 2.3.0 Master on Windows 7 prof.
>> Is this a bug or did I do anything wrong?
>> Thanks for your help
>> Jake
>> Bad request.
>> Request Details
>> - cookie_policy_enforce=false
>> - response_type=code
>> - scope=https://www.googleapis.com/auth/mapsengine
>> https://www.googleapis.com/auth/userinfo.profile
>> - redirect_uri=urn:ietf:wg:oauth:2.0:oob
>> - approval_prompt=auto
>> - state=123456789
>> - client_id=j.m at jmforestry.com
>> Jake Maier
>> 6 Lower Falls Road
>> Orland
>> ME 04472
>> 469 0231
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Ujaval Gandhi | Staff Geo Data Strategist | ujaval at google.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140304/9f8acfdb/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140304/9f8acfdb/attachment.obj>
