[Qgis-user] QGis 2.0.1 (german version): Transect with square	polygons
    Daniel88
    d.weinberg at posteo.de
    Tue Mar  4 06:48:14 PST 2014
I would like to create with QGis 2.0.1 ( Dufour , german version) several
square polygons (1km ²) that seamlessly connect to each other, so that a
strip ( transect ) of 9km times 1km length results . ( I once attached a
picture of how it should look ) -
http://www.myimg.de/?img=TransektArcMap75b51.jpg
So far I know only the corresponding functions in ArcMap from ESRI. QGis
seems equipped in the basic version with less features. Although I have the
plugin " Rectangles ovals digitizing " installed, but can not choose here
the edge length . In addition, the following square is to connect seamlessly
. In ArcMap the cursor shows me when digitizing contacts with neighboring
polygons or their vertexes or lines on , so you could work " seamlessly " .
Furthermore, each of the squares , partially each quadrant , then an
attribute (here, an air quality index) to be assigned , in accordance with
which the square to be dyed. Are different colors within a shape based on
various values (how it works in ArcMap ) possible?
 About tips on how I can tackle this project , I'd be very happy .
PS: For information on tools , etc. ..... I use the German user interface.
Best regards and thank you in advance
Daniel
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGis-2-0-1-german-version-Transect-with-square-polygons-tp5107441.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
