[Qgis-user] QGis 2.0.1 (german version): Transect with square polygons
    Andreas Neumann
    a.neumann at carto.net
    Wed Mar  5 00:18:46 PST 2014
Hi Daniel,
First I comment on your statement "QGis seems equipped in the basic
version with less features."
We don't have different versions like ESRI: basic, professional,
advanced, whatever there is available @ESRI.
Everybody gets the full version with QGIS. Of cours ESRI stuff is in
development for 30-40 years and QGIS only since 2002. So I bet there
will be some functions in ESRI that aren't available in QGIS - but also
in the opposite way. QGIS has some cool stuff that ESRI does not offer.
In QGIS there is a "plugin concept". A lot of functionality is started
as a plugin and then may make its way into core if it is popular. So if
you are missing something, be sure to also look at the plugins repository.
In your case you may want to try the "Vektor" --> "Research Tools" -->
"Vector Grid" functionality. I think it may cover some of your needs -
maybe not all. Maybe you need to postprocess the generated data to cater
to your attribute/naming needs.
As to digitizing with snapping: yes, this is available. Have a look at
"Settings" --> "Snapping Options".
Different colors based on values: of course - this is basic GIS stuff.
Don't let yourself be trapped with ArcGIS. Other GIS have different
concepts and functions. Things behave different.
Hope this helps a bit.
Andreas
Am 04.03.2014 14:48, schrieb Daniel88:
> I would like to create with QGis 2.0.1 ( Dufour , german version) several
> square polygons (1km ²) that seamlessly connect to each other, so that a
> strip ( transect ) of 9km times 1km length results . ( I once attached a
> picture of how it should look ) -
> http://www.myimg.de/?img=TransektArcMap75b51.jpg
> So far I know only the corresponding functions in ArcMap from ESRI. QGis
> seems equipped in the basic version with less features. Although I have the
> plugin " Rectangles ovals digitizing " installed, but can not choose here
> the edge length . In addition, the following square is to connect seamlessly
> . In ArcMap the cursor shows me when digitizing contacts with neighboring
> polygons or their vertexes or lines on , so you could work " seamlessly " .
> Furthermore, each of the squares , partially each quadrant , then an
> attribute (here, an air quality index) to be assigned , in accordance with
> which the square to be dyed. Are different colors within a shape based on
> various values (how it works in ArcMap ) possible?
>  About tips on how I can tackle this project , I'd be very happy .
> PS: For information on tools , etc. ..... I use the German user interface.
> Best regards and thank you in advance
> Daniel
> View this message in context: http://osgeo-org.1560.x6.nabble.com/QGis-2-0-1-german-version-Transect-with-square-polygons-tp5107441.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
