[Qgis-user] qgis2.2 claims that grass is not installed in William's version
William Kyngesburye
woklist at kyngchaos.com
Tue Mar 4 11:28:50 PST 2014
That's usually because I mess up the installer and grass.sh is not executable. Should be OK in the latest installer, and probably is if GRASS runs by itself.
Is that all that is in the processing log?
On Mar 4, 2014, at 11:59 AM, Agustin Diez-Castillo wrote:
> Processing grass algorithms claim that grass is not installed. Launching grass gives the below message [1]. In case is any help, I provide the processing log [2]. Grass runs from inside the application [3] and the grass provider points to there [4].
> [1] Missing dependency.This algorithm cannot be run :-(
> This algorithm requires GRASS to be run. Unfortunately, it seems that GRASS is not installed in your system, or it is not correctly configured to be used from QGIS
> Click here to know more about how to install and configure GRASS to be used with QGIS
> [2] processing.runalg("grass:v.voronoi","/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/tests/data/points.shp",False,False,"270778.60198,270855.745301,4458921.97814,4458983.8488",-1,0.0001,0,None)
> [3] /Applications/QGIS.app/Contents/MacOS/grass/grass.sh
> [4] /Applications/QGIS.app/Contents/MacOS/grass
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
