[Qgis-user] complete a polygon
    Blumentrath, Stefan
    Stefan.Blumentrath at nina.no
    Thu Mar  6 04:44:47 PST 2014
Not sure if I misunderstood the question...
In case my hint to "Avoid intersection" was a bit short and therefor unclear please have a look here:
http://www.qgis.org/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#avoid-intersections-of-new-polygons
"Avoid intersection"is targeted at digitizing adjacent polygons, which is what I understood was the aim...
Cheers
Stefan
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Randal Hale
Sent: 6. mars 2014 13:29
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] complete a polygon
Tata,
You are referring to a tool that is comparable to autocomplete in the ESRI world. The closest I have gotten is the autotrace plugin  (and it's not comparable - but it's closer to what you are looking for - http://www.lutraconsulting.co.uk/resources/autotrace). As for a process - the best (as far as I know and I hope I am wrong) is to digitize your work area as polylines - at the end convert them to polygons (vector -> geometry tools -> lines to polygons). It would save some clicking but would add a step (or maybe two).
Anyway - Good luck!
Randy
Randal Hale, GISP
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com<mailto:rjhale at northrivergeographic.com>
twitter:rjhale
http://about.me/rjhale
On 03/06/2014 07:05 AM, Blumentrath, Stefan wrote:
Avoid Intersection is under "Settings" --> "Snapping options".
If that is checked for your layer you can simply continue digitizing with the "create polygon" tool...
Cheers
Stefan
From: qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of SIT delle Riserve Naturali di Legambiente Sicilia
Sent: 6. mars 2014 12:30
To: Saber Razmjooei
Cc: qgis-user
Dear Saber, thank you!
But this tools allows me to complete a polygon "inside" another.
I'm searching for a tool that alow me to complete a polygon outside another, that has common sides
If I have polygon 1 and 2, andI wan to to digitize polygon 3, I'm searching a tool that allow me to digitize pol 3 without redraw the common sides with 1 and 2 (in thi case ise very simple redraw,, but with complex and natural polygons it is an heavy WORK!!)
Thank you.
Tata[cid:image001.jpg at 01CF3942.37502DE0]
Il 06/03/2014 11:14, Saber Razmjooei ha scritto:
If I have understood your question correctly, you can use AutoTrace plugin.
See more details here:
Cheers
Saber
On 6 Mar 2014 10:05, SIT delle Riserve Naturali di Legambiente Sicilia <sit at legambienteriserve.it><mailto:sit at legambienteriserve.it> wrote:
I have to add a new polygon to other existing; they have obviously
common sides; how can I draw only sides not common?
Thank you
Tata Livreri
Legambiente Comitato Regionale Siciliano
Ufficio Gestione Riserve
Sistema Informativo Territoriale
tel 0916262697 - 0906264139
www.legambienteriserve.it<http://www.legambienteriserve.it>
via Tripoli 3 - Palermo 90138
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140306/577f92ab/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140306/577f92ab/attachment.jpg>
