[Qgis-user] complete a polygon
Lluís Vicens
lluis at sigte.udg.es
Fri Mar 7 02:11:52 PST 2014
On 06/03/14 13:44, Blumentrath, Stefan wrote:
> Not sure if I misunderstood the question...
> In case my hint to "Avoid intersection" was a bit short and therefor
> unclear please have a look here:
> http://www.qgis.org/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#avoid-intersections-of-new-polygons
> "Avoid intersection"is targeted at digitizing adjacent polygons, which
> is what I understood was the aim...
Hi Tata,
Hope this helps to clarify what Stefan says:
http://youtu.be/dOANChaWUwI
Cheers,
Lluís
> Cheers
> Stefan
> *From:*qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Randal Hale
> *Sent:* 6. mars 2014 13:29
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] complete a polygon
> Tata,
> You are referring to a tool that is comparable to autocomplete in the
> ESRI world. The closest I have gotten is the autotrace plugin (and
> it's not comparable - but it's closer to what you are looking for -
> http://www.lutraconsulting.co.uk/resources/autotrace). As for a
> process - the best (as far as I know and I hope I am wrong) is to
> digitize your work area as polylines - at the end convert them to
> polygons (vector -> geometry tools -> lines to polygons). It would
> save some clicking but would add a step (or maybe two).
> Anyway - Good luck!
> Randy
> Randal Hale, GISP
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611rjhale at northrivergeographic.com <mailto:rjhale at northrivergeographic.com>
> twitter:rjhale
> http://about.me/rjhale
> On 03/06/2014 07:05 AM, Blumentrath, Stefan wrote:
> Avoid Intersection is under "Settings" à"Snapping options".
> If that is checked for your layer you can simply continue
> digitizing with the "create polygon" tool...
> Cheers
> Stefan
> <mailto:qgis-user-bounces at lists.osgeo.org>
> [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf Of *SIT
> delle Riserve Naturali di Legambiente Sicilia
> *Sent:* 6. mars 2014 12:30
> *To:* Saber Razmjooei
> *Cc:* qgis-user
> Dear Saber, thank you!
> But this tools allows me to complete a polygon "inside" another.
> I'm searching for a tool that alow me to complete a polygon
> outside another, that has common sides
> If I have polygon 1 and 2, andI wan to to digitize polygon 3, I'm
> searching a tool that allow me to digitize pol 3 without redraw
> the common sides with 1 and 2 (in thi case ise very simple
> redraw,, but with complex and natural polygons it is an heavy WORK!!)
> Thank you.
> Tata
> Il 06/03/2014 11:14, Saber Razmjooei ha scritto:
> If I have understood your question correctly, you can use AutoTrace plugin.
> See more details here:
> Cheers
> Saber
> On 6 Mar 2014 10:05, SIT delle Riserve Naturali di Legambiente Sicilia<sit at legambienteriserve.it> <mailto:sit at legambienteriserve.it> wrote:
> Hi,
> I have to add a new polygon to other existing; they have obviously
> common sides; how can I draw only sides not common?
> Thank you
> Tata Livreri
> Legambiente Comitato Regionale Siciliano
> Ufficio Gestione Riserve
> Sistema Informativo Territoriale
> tel 0916262697 - 0906264139
> www.legambienteriserve.it <http://www.legambienteriserve.it>
> via Tripoli 3 - Palermo 90138
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
Lluís Vicens
SIGTE - Universitat de Girona
Pl. Ferrater Mora, 1
17071 Girona
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140307/a165452e/attachment.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140307/a165452e/attachment.jpe>
