[Qgis-user] complete a polygon
sit sit at legambienteriserve.it
Mon Mar 10 10:37:53 PDT 2014
It works!
Thank you very much, Stephan!
Tata
Legambiente - Comitato Regionale Siciliano
Gestione Riserve Naturali
Sistema Informativo Territoriale
tel 00390916262697
fax 00390916264139
Da: "Blumentrath, Stefan" Stefan.Blumentrath at nina.no
A: "SIT delle Riserve Naturali di Legambiente Sicilia" sit at legambienteriserve.it,"Saber Razmjooei" saber.razmjooei at lutraconsulting.com
Cc: "qgis-user" Qgis-user at lists.osgeo.org
Data: Thu, 6 Mar 2014 12:05:15 +0000
Oggetto: RE: [Qgis-user] complete a polygon
> Avoid Intersection is under “Settings”
à
“Snapping options”.
> If that is checked for your layer you can simply continue digitizing with the “create polygon” tool…
> Cheers
> Stefan
> From: qgis-user-bounces at lists.osgeo.org
 [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of SIT delle Riserve Naturali di Legambiente Sicilia
> Sent: 6. mars 2014 12:30
> To: Saber Razmjooei
> Cc: qgis-user
> Subject: Re: [Qgis-user] complete a polygon
> Dear Saber, thank you!
But this tools allows me to complete a polygon "inside" another.
I'm searching for a tool that alow me to complete a polygon outside another, that has common sides
If I have polygon 1 and 2, andI wan to to digitize polygon 3, I'm searching a tool that allow me to digitize pol 3 without redraw the common sides with 1 and 2 (in thi case ise very simple redraw,, but with complex and natural polygons it is an heavy WORK!!)
Thank you.
Tata
> Il 06/03/2014 11:14, Saber Razmjooei ha scritto:
> If I have understood your question correctly, you can use AutoTrace plugin.
> See more details here:
> http://www.lutraconsulting.co.uk/resources/autotrace
> Cheers
> Saber
> On 6 Mar 2014 10:05, SIT delle Riserve Naturali di Legambiente Sicilia <sit at legambienteriserve.it> wrote:
> Hi,
> I have to add a new polygon to other existing; they have obviously
> common sides; how can I draw only sides not common?
> Thank you
> Tata Livreri
> Legambiente Comitato Regionale Siciliano
> Ufficio Gestione Riserve
> tel 0916262697 - 0906264139
> www.legambienteriserve.it
> via Tripoli 3 - Palermo 90138
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140310/29f2d4f1/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140310/29f2d4f1/attachment.jpg>
