[Qgis-user] PostGIS raster access in QGIS using DBManager (or wktraster)
José Pedro Santos
zpsantos1 at hotmail.com
Fri Mar 7 01:40:43 PST 2014
Ciao Guido,
DBManager is only for vector layers..In the version 1.8 existed a plugin for importing raster layers but wasn't update for this new version.
Regards,
José Santos
To: qgis-user at lists.osgeo.org
Date: Fri, 7 Mar 2014 07:51:33 +0100
Subject: [Qgis-user] PostGIS raster access in QGIS using DBManager (or wktraster)
Dear QGIS users,
[This was posted on QGIS developer as well, but maybe I should seek the solution here]
I am using QGIS 2.2 .0 (Valmiera) and trying to load a raster query result via DBManager, using the following query:
select 1 as rid, st_union(st_band(rast, '4,3,2') ) as rast
from o_8_lc81970232013202lgn00_all_rds_sub, municipalities
where municipalities.wkb_geometry && rast
and munname = 'Veendam'
(in short: Band 4,3,2 of a raster2pgsql-loaded Landsat-8 image (overview 8 version) for a "municipality" polygon (administrative commune boundary).
Execute (F5) correctly returns a single row (and I can save the union result with ST_AsTIFF() to file in a script)
When I try to "Load as a new layer" to visualise the result in QGIS, I get the following error message:
Erroneous query: SELECT DISTINCT upper(geometrytype("rast")),st_srid("rast") FROM (select 1 as rid, st_union(st_band(rast, '4,3,2') ) as rast
from o_8_lc81970232013202lgn00_all_rds_sub, gemeentegebieden
where gemeentegebieden.wkb_geometry && rast
and gemnaam = 'Veendam'
) AS "subQuery_0" returned 7 [ERROR: function geometrytype(raster) does not exist
LINE 1: SELECT DISTINCT upper(geometrytype("rast")),st_srid("rast") ...
HINT: No function matches the given name and argument types. You might need to add explicit type casts.
Apparently, my query get "wrapped" in the SELECT DISTINCT outer query above (which obviously does not work).
Is this a known issue, and, if so, can it be modified, for instance by providing explicitly geometrytype and srid (and if so, how?).
I also checked out the wktraster plugin, but that does not work for 2.2. Is an upgrade expected soon [or should I try writing it myself].
Thanks for all the wonderful stuff,
Guido Lemoine
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140307/57cc9f6d/attachment.html>
