[Qgis-user] PostGIS raster access in QGIS using DBManager (or wktraster)
José Carlos Martínez Llario
jomarlla at cgf.upv.es
Fri Mar 7 01:45:13 PST 2014
you just have to add the layer from db manager directly, it is working
with raster too.
I already did few days ago with QGIS 2.2 with PostGIS Raster, it worked
really well better than other previous versions of QGIS.
cheers,
Jose Carlos Martinez
On 07/03/2014 10:40, José Pedro Santos wrote:
> Ciao Guido,
> DBManager is only for vector layers..In the version 1.8 existed a
> plugin for importing raster layers but wasn't update for this new
> version.
> Regards,
> José Santos
> From: guido.lemoine at jrc.ec.europa.eu
> To: qgis-user at lists.osgeo.org
> Date: Fri, 7 Mar 2014 07:51:33 +0100
> Subject: [Qgis-user] PostGIS raster access in QGIS using DBManager (or
> wktraster)
> Dear QGIS users,
> [This was posted on QGIS developer as well, but maybe I should seek
> the solution here]
> I am using QGIS 2.2 .0 (Valmiera) and trying to load a raster query
> result via DBManager, using the following query:
> select 1 as rid, st_union(st_band(rast, '4,3,2') ) as rast
> from o_8_lc81970232013202lgn00_all_rds_sub, municipalities
> where municipalities.wkb_geometry && rast
> and munname = 'Veendam'
> (in short: Band 4,3,2 of a raster2pgsql-loaded Landsat-8 image
> (overview 8 version) for a "municipality" polygon (administrative
> commune boundary).
> Execute (F5) correctly returns a single row (and I can save the union
> result with ST_AsTIFF() to file in a script)
> When I try to "Load as a new layer" to visualise the result in QGIS, I
> get the following error message:
> Erroneous query: SELECT DISTINCT
> upper(geometrytype("rast")),st_srid("rast") FROM (select 1 as rid,
> from o_8_lc81970232013202lgn00_all_rds_sub, gemeentegebieden
> where gemeentegebieden.wkb_geometry && rast
> and gemnaam = 'Veendam'
> ) AS "subQuery_0" returned 7 [ERROR: function geometrytype(raster)
> does not exist
> LINE 1: SELECT DISTINCT upper(geometrytype("rast")),st_srid("rast") ...
> HINT: No function matches the given name and argument types. You
> might need to add explicit type casts.
> Apparently, my query get "wrapped" in the SELECT DISTINCT outer query
> above (which obviously does not work).
> Is this a known issue, and, if so, can it be modified, for instance by
> providing explicitly geometrytype and srid (and if so, how?).
> I also checked out the wktraster plugin, but that does not work for
> 2.2. Is an upgrade expected soon [or should I try writing it myself].
> Thanks for all the wonderful stuff,
> Guido Lemoine
> _______________________________________________ Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140307/5c6d44d9/attachment.html>
