[Qgis-user] PostGIS raster access in QGIS using DBManager (or wktraster)
Guido Lemoine
guido.lemoine at jrc.ec.europa.eu
Fri Mar 7 03:29:40 PST 2014
Jose Carlos,
Thanks for your answers. I know the option to Add to Canvas for a raster
layer that shows up in the DBManager interface.
Problem is that I connect over the network, and Landsat images are typically
150 Mb per band.
This is why I prefer to select well-delineated areas that are reasonable in
size, for which the raster selection query seem to be just the right
solution.
Even better would be a Add PostGIS raster layer on the left menu, that
would logically go for the re-sampled pyramid layers, if available in the
database, or warn when really big images would be requested [over a network
connection].
As a start, I guess I will have to dig out the old version of DBManager and
restore the raster functionality
Guido
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of José Carlos Martínez
Llario
Sent: 07 March 2014 10:45
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] PostGIS raster access in QGIS using DBManager (or
wktraster)
you just have to add the layer from db manager directly, it is working with
raster too.
I already did few days ago with QGIS 2.2 with PostGIS Raster, it worked
really well better than other previous versions of QGIS.
cheers,
Jose Carlos Martinez
On 07/03/2014 10:40, José Pedro Santos wrote:
Ciao Guido,
DBManager is only for vector layers..In the version 1.8 existed a plugin for
importing raster layers but wasn't update for this new version.
Regards,
José Santos
_____
Date: Fri, 7 Mar 2014 07:51:33 +0100
Subject: [Qgis-user] PostGIS raster access in QGIS using DBManager (or
wktraster)
Dear QGIS users,
[This was posted on QGIS developer as well, but maybe I should seek the
solution here]
I am using QGIS 2.2 .0 (Valmiera) and trying to load a raster query result
via DBManager, using the following query:
select 1 as rid, st_union(st_band(rast, '4,3,2') ) as rast
from o_8_lc81970232013202lgn00_all_rds_sub, municipalities
where municipalities.wkb_geometry && rast
and munname = 'Veendam'
(in short: Band 4,3,2 of a raster2pgsql-loaded Landsat-8 image (overview 8
version) for a "municipality" polygon (administrative commune boundary).
Execute (F5) correctly returns a single row (and I can save the union result
with ST_AsTIFF() to file in a script)
When I try to "Load as a new layer" to visualise the result in QGIS, I get
the following error message:
Erroneous query: SELECT DISTINCT upper(geometrytype("rast")),st_srid("rast")
FROM (select 1 as rid, st_union(st_band(rast, '4,3,2') ) as rast
from o_8_lc81970232013202lgn00_all_rds_sub, gemeentegebieden
where gemeentegebieden.wkb_geometry && rast
and gemnaam = 'Veendam'
) AS "subQuery_0" returned 7 [ERROR: function geometrytype(raster) does not
exist
LINE 1: SELECT DISTINCT upper(geometrytype("rast")),st_srid("rast") ...
HINT: No function matches the given name and argument types. You might need
to add explicit type casts.
Apparently, my query get "wrapped" in the SELECT DISTINCT outer query above
(which obviously does not work).
Is this a known issue, and, if so, can it be modified, for instance by
providing explicitly geometrytype and srid (and if so, how?).
I also checked out the wktraster plugin, but that does not work for 2.2. Is
an upgrade expected soon [or should I try writing it myself].
Thanks for all the wonderful stuff,
Guido Lemoine
_______________________________________________ Qgis-user mailing list
Qgis-user at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140307/a72b9c47/attachment.html>
