[Qgis-user] Symbology Export
Andreas Neumann a.neumann at carto.net
Mon Mar 10 08:30:46 PDT 2014
Hi Jonathan,
The thread you are quoting is from 2011. The OGR feature styling was
introduced later (in late 2012 or early 2013 I think).
So did you really test KML export with "Feature symbology" or "symbol
layer symbology"?
I just tested it with QGIS master and with line features and different
line colors. It worked. What did you do that it did not work? What
steps? Do you have project/data to share?
Andreas
Am 10.03.2014 15:07, schrieb Jonathan Moules:
> Hi Andreas,
> I don't believe QGIS exports any KML styling. I was interested in doing a
> full style KML export and got this -
> http://osgeo-org.1560.x6.nabble.com/styling-a-KML-KMZ-file-using-QGIS-td4125929.html-
> seems not to be possible.
> I'll open a ticket for removing/hiding it. I'd suggest you open a ticket
> for expanding it - you know more about it so will be able to write a better
> ticket about it. :-)
> Regards,
> Jonathan
> On 10 March 2014 14:59, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi,
>> Actually it is not tied to DXF, but DXF was the reason why it was
>> introduced. It is just generic OGR feature styling.
>> Maybe it should be removed/hidden/disabled because DXF now has its
>> separate export. Maybe assign Marco Hugentobler to this ticket as he
>> worked on this.
>> Unless someone wants to work on it and improve it.
>> Does it not work at all with KML? Not even a simple line color?
>> Andreas
>> Am 10.03.2014 14:49, schrieb Jonathan Moules:
>>> Hi Andreas,
>>> Thanks for the information. I'd suggest it should probably be removed
>>> until/unless it is fleshed out as you note. Either that or changed to be
>> a
>>> "Datasource option" specific for DXF.
>>> Should I open a ticket for this?
>>> Cheers,
>>> Jonathan
>>> On 10 March 2014 14:35, Andreas Neumann <a.neumann at carto.net> wrote:
>>>> Hi Jonathan,
>>>> This was originally introduced for DXF export to keep symbology as good
>>>> as it can - which is now in its separate function (Project -> DXF
>>>> Export) and not in the "save layer as" anymore.
>>>> It uses the OGR feature styling, which in itself is rather limiting.
>>>> This isn't widely implemented and tested. Would be nice if some devs or
>>>> interested customers/users could give it some love.
>>>> Andreas
>>>> Am 10.03.2014 13:45, schrieb Jonathan Moules:
>>>>> Hi List,
>>>>> General curiosity question.
>>>>> When using "Save Vector Layer as" to save a vector layer, there's an
>>>>> optioon:
>>>>> "Symbology Export"
>>>>> This in turn has three options:
>>>>> "No Symbology"
>>>>> "Feature symbology"
>>>>> "Symbol layer symbology"
>>>>> What does this do? I've tried exporting to both KML and TAB files using
>>>>> these options but they don't appear to keep the symbology.
>>>>> Cheers,
>>>>> Jonathan
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
