[Qgis-user] Intersecting points and polygons
Leandro Girardin
leandrogirardin at yahoo.com.ar
Tue Mar 11 04:22:25 PDT 2014
El 11/03/14 05:50, Lynkos escribió:
> Back again needing your help...
> I have a point shapefile containing bird observations and another
> polygon shapefile containing the boundaries of local authority areas.
> Using these, I need to add a column to the point shapefile attribute
> table containing the name of the local authority area in which the
> point falls.
> If the two files were both polygons, I would do an intersect or union.
> But doing this with a point file and a polygon file creates a
> shapefile, but without merging the attribute tables correctly. I get
> all the headings of both files, but the attributes of only one or the
> other of the files.
> I'm using QGIS 2.2. Thanks for any suggestions on how to achieve my
> result, Sarah.
> Qgis-user mailing list
Sarah, this can be done with, join attributes from localization, from
ftools plugins.
http://www.qgis.org/es/docs/user_manual/plugins/plugins_ftools.html
Cheers
Leandro.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140311/dc4ec877/attachment.html>
