[Qgis-user] How to represent Water Bore/Borewells in 3D view using	qgis..?
    josef k
    groundwatergis at gmail.com
    Sat Mar 15 13:41:54 PDT 2014
You can also use the Qgis2threejs plugin. I use it (with data from
Midvatten plugin) to create 3D borehole plots like this:
http://goo.gl/8pDR4o
As Martin said, you can use Midvatten plugin although it is not 3D. But you
can get section plots (experimental version):
http://hydrogeotools.blogspot.se/2014/01/section-plot-in-midvatten-plugin-for.html
I also have plans to add a new feature to Midvatten plugin: to export
borehole stratigraphy data into layers which can easily be used with
Qgis2threejs for a 3D borehole plot.
/Josef
> Date: Sat, 15 Mar 2014 01:29:06 -0700 (PDT)
> From: gene <martin.laloux at gmail.com>
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] How to represent Water Bore/Borewells in 3D
>         view    using qgis..?
> Message-ID: <1394872146331-5129185.post at n6.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> Look at  Is there are QGIS plugin to allow the 3d visualisation of
> geological
> borehole data similar to the functionality of Target for ArcGIS?
> http://gis.stackexchange.com/questions/41701/is-there-are-qgis-plugin-to-allow-the-3d-visualisation-of-geological-borehole-da/41719#41719
> - With Python and modules that allow the 3D representation (matplotlib,
> visvis, Mayavi) ( For geologists: 3D geological boreholes
> http://osgeo-org.1560.x6.nabble.com/For-geologists-3D-geological-boreholes-td5007085.html
> <http://osgeo-org.1560.x6.nabble.com/file/n5129185/sondages2.jpg>
> - With GRASS GIS ( Automatic 3D geological boreholes representation
> (automate v.extrude from a table ?): my solution in Python
> http://osgeo-org.1560.x6.nabble.com/Automatic-3D-geological-boreholes-representation-automate-v-extrude-from-a-table-my-solution-in-Pythn-td4978801.html
> <http://osgeo-org.1560.x6.nabble.com/file/n5129185/sonddelaunayok.jpg>
> - you can also use the QGIS  Midvatten
> <https://plugins.qgis.org/plugins/midvatten/>   plugin
> (geological/hydrogeological -> not really 3D)
> <http://osgeo-org.1560.x6.nabble.com/file/n5129185/midvatten1.jpg>
> http://osgeo-org.1560.x6.nabble.com/How-to-represent-Water-Bore-Borewells-in-3D-view-using-qgis-tp5129181p5129185.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140315/8aa1d153/attachment.html>
