[Qgis-user] How to represent Water Bore/Borewells in 3D view using qgis..?
Carlos Cerdán sig.upagu at gmail.com
Sat Mar 15 17:41:27 PDT 2014
Thank you Josef!!!!
It's wonderful, I had not idea about qgis2threejs plugin. I just used it
with my own data and my jaw is still down: wooow it's really nice 3D.
Best wishes
Carlos
2014-03-15 15:41 GMT-05:00 josef k <groundwatergis at gmail.com>:
> You can also use the Qgis2threejs plugin. I use it (with data from
> Midvatten plugin) to create 3D borehole plots like this:
> http://goo.gl/8pDR4o
> As Martin said, you can use Midvatten plugin although it is not 3D. But
> you can get section plots (experimental version):
> http://hydrogeotools.blogspot.se/2014/01/section-plot-in-midvatten-plugin-for.html
> I also have plans to add a new feature to Midvatten plugin: to export
> borehole stratigraphy data into layers which can easily be used with
> Qgis2threejs for a 3D borehole plot.
> /Josef
>> Date: Sat, 15 Mar 2014 01:29:06 -0700 (PDT)
>> From: gene <martin.laloux at gmail.com>
>> To: qgis-user at lists.osgeo.org
>> Subject: Re: [Qgis-user] How to represent Water Bore/Borewells in 3D
>>         view    using qgis..?
>> Message-ID: <1394872146331-5129185.post at n6.nabble.com>
>> Content-Type: text/plain; charset=us-ascii
>> Look at  Is there are QGIS plugin to allow the 3d visualisation of
>> geological
>> borehole data similar to the functionality of Target for ArcGIS?
>> http://gis.stackexchange.com/questions/41701/is-there-are-qgis-plugin-to-allow-the-3d-visualisation-of-geological-borehole-da/41719#41719
>> - With Python and modules that allow the 3D representation (matplotlib,
>> visvis, Mayavi) ( For geologists: 3D geological boreholes
>> http://osgeo-org.1560.x6.nabble.com/For-geologists-3D-geological-boreholes-td5007085.html
>> <http://osgeo-org.1560.x6.nabble.com/file/n5129185/sondages2.jpg>
>> - With GRASS GIS ( Automatic 3D geological boreholes representation
>> (automate v.extrude from a table ?): my solution in Python
>> http://osgeo-org.1560.x6.nabble.com/Automatic-3D-geological-boreholes-representation-automate-v-extrude-from-a-table-my-solution-in-Pythn-td4978801.html
>> <http://osgeo-org.1560.x6.nabble.com/file/n5129185/sonddelaunayok.jpg>
>> - you can also use the QGIS  Midvatten
>> <https://plugins.qgis.org/plugins/midvatten/>   plugin
>> (geological/hydrogeological -> not really 3D)
>> <http://osgeo-org.1560.x6.nabble.com/file/n5129185/midvatten1.jpg>
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/How-to-represent-Water-Bore-Borewells-in-3D-view-using-qgis-tp5129181p5129185.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140315/02ce2197/attachment.html>
