[Qgis-user] How to represent Water Bore/Borewells in 3D view using qgis..?
    josef k
    groundwatergis at gmail.com
    Mon Mar 17 05:01:13 PDT 2014
Carlos,
I just made a pull request for Qgis2threejs to enable the use of multiple
DEMs to illustrate geological layers: http://goo.gl/rVUwmn
I do not know about your usage but for me this is revolutionary in the FOSS
world.
(I considered using wireframes for the subsurface layers but ended up not
doing so, although it was not an obvious decision: http://goo.gl/vWN3kr)
/Josef
Date: Sat, 15 Mar 2014 19:41:27 -0500
> From: Carlos Cerd?n <sig.upagu at gmail.com>
> To: qgis-user <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] How to represent Water Bore/Borewells in 3D
>         view using qgis..?
> Message-ID:
> CAFvg7Wiu6qghK7otShjwGNSRi-Tio+mWNd77bxhexV8i9LkVqw at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Thank you Josef!!!!
> It's wonderful, I had not idea about qgis2threejs plugin. I just used it
> with my own data and my jaw is still down: wooow it's really nice 3D.
> Best wishes
> Carlos
> 2014-03-15 15:41 GMT-05:00 josef k <groundwatergis at gmail.com>:
> > You can also use the Qgis2threejs plugin. I use it (with data from
> > Midvatten plugin) to create 3D borehole plots like this:
> > http://goo.gl/8pDR4o
> > As Martin said, you can use Midvatten plugin although it is not 3D. But
> > you can get section plots (experimental version):
> http://hydrogeotools.blogspot.se/2014/01/section-plot-in-midvatten-plugin-for.html
> > I also have plans to add a new feature to Midvatten plugin: to export
> > borehole stratigraphy data into layers which can easily be used with
> > Qgis2threejs for a 3D borehole plot.
> > /Josef
> >> Date: Sat, 15 Mar 2014 01:29:06 -0700 (PDT)
> >> From: gene <martin.laloux at gmail.com>
> >> To: qgis-user at lists.osgeo.org
> >>         view    using qgis..?
> >> Message-ID: <1394872146331-5129185.post at n6.nabble.com>
> >> Content-Type: text/plain; charset=us-ascii
> >> Look at  Is there are QGIS plugin to allow the 3d visualisation of
> >> geological
> >> borehole data similar to the functionality of Target for ArcGIS?
> http://gis.stackexchange.com/questions/41701/is-there-are-qgis-plugin-to-allow-the-3d-visualisation-of-geological-borehole-da/41719#41719
> >> - With Python and modules that allow the 3D representation (matplotlib,
> >> visvis, Mayavi) ( For geologists: 3D geological boreholes
> http://osgeo-org.1560.x6.nabble.com/For-geologists-3D-geological-boreholes-td5007085.html
> >> <http://osgeo-org.1560.x6.nabble.com/file/n5129185/sondages2.jpg>
> >> - With GRASS GIS ( Automatic 3D geological boreholes representation
> >> (automate v.extrude from a table ?): my solution in Python
> http://osgeo-org.1560.x6.nabble.com/Automatic-3D-geological-boreholes-representation-automate-v-extrude-from-a-table-my-solution-in-Pythn-td4978801.html
> >> <http://osgeo-org.1560.x6.nabble.com/file/n5129185/sonddelaunayok.jpg>
> >> - you can also use the QGIS  Midvatten
> >> <https://plugins.qgis.org/plugins/midvatten/>   plugin
> >> (geological/hydrogeological -> not really 3D)
> >> <http://osgeo-org.1560.x6.nabble.com/file/n5129185/midvatten1.jpg>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140317/9450f49e/attachment.html>
