[Qgis-user] How to represent Water Bore/Borewells in 3D view using qgis..?
Andreas Neumann
a.neumann at carto.net
Mon Mar 17 05:22:38 PDT 2014
Nice!
I wonder if we could do something so that the top surface can be seen
from below? Currently, if you look from below it is just fully
transparent - not so optimal in this case.
The other thing that would be very nice if you could interact with these
objects - click on a borehole and get the attribute data. Is it
technically to add events to objects?
Andreas
Am 17.03.2014 12:01, schrieb josef k:
> Carlos,
> I just made a pull request for Qgis2threejs to enable the use of multiple
> DEMs to illustrate geological layers: http://goo.gl/rVUwmn
> I do not know about your usage but for me this is revolutionary in the FOSS
> world.
> (I considered using wireframes for the subsurface layers but ended up not
> doing so, although it was not an obvious decision: http://goo.gl/vWN3kr)
> /Josef
