[Qgis-user] How to represent Water Bore/Borewells in 3D view using qgis..?
    Andreas Neumann
    a.neumann at carto.net
    Mon Mar 17 07:46:18 PDT 2014
Hi Josef,
If I tilt the model to look from below up to the surface, the surface
disappears and I can only see the boreholes.
See screenshots here:
http://webgis.uster.ch/temp/qgisthreejs1.png (surface partially disappears)
http://webgis.uster.ch/temp/qgisthreejs2.png (surface fully disappears)
Is this consistent to what you see?
Would be nice to see the surface from below - something like this cave
system visualization here:
http://www.carto.net/neumann/diplomarbeit/img81.png
or
http://www.carto.net/neumann/diplomarbeit/img80.png
Andreas
Am 17.03.2014 14:08, schrieb josef k:
> Andreas,
> I already included a small fix to make the top surface being visible from
> below. Have close look here: http://goo.gl/8pDR4o (Or maybe I
> misunderstood, was it something else that you had in mind?)
> Unfortunately I do not know how to interact with the objects, but I do
> agree - that would be a great enhancement.
> /Josef
> Date: Mon Mar 17 05:22:38 PDT 2014
>> From: Andreas Neumann <a.neumann at carto.net>
>> Nice!
>> I wonder if we could do something so that the top surface can be seen
>> from below? Currently, if you look from below it is just fully
>> transparent - not so optimal in this case.
>> The other thing that would be very nice if you could interact with these
>> objects - click on a borehole and get the attribute data. Is it
>> technically to add events to objects?
>> Andreas
>> Am 17.03.2014 12:01, schrieb josef k:
>> * Carlos, *>
>> * I just made a pull request for Qgis2threejs to enable the use of
>> multiple *>
>> * DEMs to illustrate geological layers: http://goo.gl/rVUwmn
>> <http://goo.gl/rVUwmn> *>
>> * I do not know about your usage but for me this is revolutionary in the
>> FOSS *>
>> * world. *>
>> * (I considered using wireframes for the subsurface layers but ended up
>> not *>
>> * doing so, although it was not an obvious decision: http://goo.gl/vWN3kr
>> <http://goo.gl/vWN3kr>) *>* /Josef*
> Qgis-user mailing list
