[Qgis-user] How to represent Water Bore/Borewells in 3D view using qgis..?
    josef k
    groundwatergis at gmail.com
    Mon Mar 17 07:57:29 PDT 2014
Andreas,
I am sorry, this is the correct link: http://goo.gl/rVUwmn (full path
https://googledrive.com/host/0B1vhrFUx2OZBZFhfWGZoNDdLc3M/20140317120657.html
/Josef
Date: Mon Mar 17 07:46:18 PDT 2014
> From: Andreas Neumann <a.neumann at carto.net>
> Hi Josef,
> If I tilt the model to look from below up to the surface, the surface
> disappears and I can only see the boreholes.
> See screenshots here:
> http://webgis.uster.ch/temp/qgisthreejs1.png (surface partially
> disappears)
> http://webgis.uster.ch/temp/qgisthreejs2.png (surface fully disappears)
> Is this consistent to what you see?
> Would be nice to see the surface from below - something like this cave
> system visualization here:
> http://www.carto.net/neumann/diplomarbeit/img81.png
> or
> http://www.carto.net/neumann/diplomarbeit/img80.png
> Andreas
> Am 17.03.2014 14:08, schrieb josef k:
> * Andreas, *>
> * I already included a small fix to make the top surface being visible
> from *>
> * below. Have close look here: http://goo.gl/8pDR4o <http://goo.gl/8pDR4o>
> (Or maybe I *>
> * misunderstood, was it something else that you had in mind?) *>
> * Unfortunately I do not know how to interact with the objects, but I do *
> * agree - that would be a great enhancement. *>
> * /Josef *>
> * Date: Mon Mar 17 05:22:38 PDT 2014 *>>
> * From: Andreas Neumann <a.neumann at carto.net
> <http://lists.osgeo.org/mailman/listinfo/qgis-user>> *>>
> * Nice! *>>
> * I wonder if we could do something so that the top surface can be seen *
> * from below? Currently, if you look from below it is just fully *>>
> * transparent - not so optimal in this case. *>>
> * The other thing that would be very nice if you could interact with these
> * objects - click on a borehole and get the attribute data. Is it *>>
> * technically to add events to objects? *>>
> * Andreas *>>
> * Am 17.03.2014 12:01, schrieb josef k: *>>>
> * * Carlos, *> *>>
> * * I just made a pull request for Qgis2threejs to enable the use of *>>
> * multiple *> *>>
> * * DEMs to illustrate geological layers: http://goo.gl/rVUwmn
> <http://goo.gl/rVUwmn> *>>
> * <http://goo.gl/rVUwmn <http://goo.gl/rVUwmn>> *> *>>
> * * I do not know about your usage but for me this is revolutionary in the
> * FOSS *> *>>
> * * world. *> *>>
> * * (I considered using wireframes for the subsurface layers but ended up *
> * not *> *>>
> * * doing so, although it was not an obvious decision:
> http://goo.gl/vWN3kr <http://goo.gl/vWN3kr> *>>
> * <http://goo.gl/vWN3kr <http://goo.gl/vWN3kr>>) *>* /Josef* *>
> * _______________________________________________ *>
> * Qgis-user mailing list *>
> * Qgis-user at lists.osgeo.org
> <http://lists.osgeo.org/mailman/listinfo/qgis-user> *>*
> <http://lists.osgeo.org/mailman/listinfo/qgis-user>*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140317/efd45384/attachment.html>
