[Qgis-user] Enlace tablas QGIS / Tables joins QGIS
Alexandre Neto senhor.neto at gmail.com
Fri Mar 21 02:33:06 PDT 2014
Hello Miguel,
There is a new feature in QGIS 2.2 Valmiera, that might interest you. It's
called relations and can be accessed by going to the project properties in
Project > Project Properties > Relations. This will allow 1:n relations,
this relations will be available in feature form widgets.
More information in here:
http://blog.vitu.ch/10112013-1201/qgis-relations
Alexandre Neto
PS: There is also a Spanish mailing list available
http://osgeo-org.1560.x6.nabble.com/QGIS-es-f5092059.html
2014-03-21 9:17 GMT+00:00 Lluís Vicens <lluis at sigte.udg.es>:
> On 20/03/14 13:41, Miguel Carroza wrote:
>> Hola
>> Alguién sabe como puedo enlazar dos tablas mediante un campo común como
>> se puede hacer en GvSIG.(El enlace no es persistente entre sesiones.
>> Permite cardinalidades de tipo uno a muchos. Las vistas de tabla permanecen
>> separadas)
>> Gracias
> Hi Miguel,
> The language of this user mailing list is English so, if you expect a
> quick response, you'd better ask in English rather than in Spanish. In any
> case, you can do a join through the MMQGIS plugin (MMQGIS > Combine >
> Attributes join from CSV file). So, you should prior transform the table
> you wish to join, to a CSV file.
> Hola Miguel,
> En QGIS puedes realizar un join entre tablas mediante el plugin MMQGIS:
> MMQGIS > Combine > Attributes join from CSV file. Así, antes de nada,
> deberás convertir la tabla que deseas unir a tu capa, al formato CSV
> Saludos,
> Lluís
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Lluís Vicens
> SIGTE - Universitat de Girona
> Pl. Ferrater Mora, 1
> 17071   Girona
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140321/b895364e/attachment.html>
