[Qgis-user] Is there way to print out a layered PDF-document?
    Järnefelt Jouko
    Jouko.Jarnefelt at tampere.fi
    Fri Mar 21 03:13:00 PDT 2014
Hey,
Thanks Joachim for your answer, and pardon me because I wasn’t clear enough.
I know how to print out a PDF… but the thing what I’m trying to do is to print out a PDF-document that has preserved the same layers which have been active in QGIS workspace. This is possible in MapInfo but I’m interested to know if there is similar function in QGIS… or any workaround.
Cheers to all,
Jouko
Lähettäjä: Joachim Józefowicz [mailto:joachimjozefowicz at gmail.com]
Lähetetty: 21. maaliskuuta 2014 11:14
Vastaanottaja: Järnefelt Jouko; Qgis List
Aihe: Re: [Qgis-user] Is there way to print out a layered PDF-document?
Of course.
Project -> New Print
In Print Window
Print -> Export like a PDF.
------ Wiadomość oryginalna ------
Od: "Järnefelt Jouko" <Jouko.Jarnefelt at tampere.fi<mailto:Jouko.Jarnefelt at tampere.fi>>
Do: "Qgis List" <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>
Wysłano: 2014-03-21 08:02:08
Temat: [Qgis-user] Is there way to print out a layered PDF-document?
Hey all.
I have a simple question for which I haven’t been able to find answer. Is there way to print out a layered PDF-document?
Thanks for your help!
Jouko
City of Tampere
Department of Land use and Planning
Finland
Lähettäjä: qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org> [mailto:qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>] Puolesta ELHOA
Lähetetty: 21. maaliskuuta 2014 0:41
Vastaanottaja: Carol Kraemer
Kopio: Qgis List
Aihe: Re: [Qgis-user] How to darken a .sid layer?
Thanks Carol,
I was able to darken my .sid layer using the method you suggested.  Turned out pretty good.
Mike K
Sent from my iPhone
On Mar 19, 2014, at 4:43 PM, Carol Kraemer <cakraemer at northrivergeographic.com<mailto:cakraemer at northrivergeographic.com>> wrote:
Mike,
When I was playing with the SID I have, I was able to use a combination of tools under the Color Rendering section to darken and enhance the image. For example, I adjusted Brightness and Contrast to bring out the colors. I've attached a before and after to show the difference.
Hope that helps!
-Carol
Carol Kraemer
North River Geographic Systems, Inc
http://www.northrivergeographic.com<http://www.northrivergeographic.com/>
404.431.0125 cakraemer at northrivergeographic.com<mailto:cakraemer at northrivergeographic.com>
On Wed, Mar 19, 2014 at 4:23 PM, ELHOA <tmike.elhoa at comcast.net<mailto:tmike.elhoa at comcast.net>> wrote:
Hello Carol,
Yes on my attempted method.
I'm trying to darken the photo, (.sid), so I can get more contrast with other layers which are overlaid on top of it; roads, parcels, rivers, etc.
Sent from my iPhone
On Mar 19, 2014, at 3:26 PM, Carol Kraemer <cakraemer at northrivergeographic.com<mailto:cakraemer at northrivergeographic.com>> wrote:
Hello Mike,
You've been using the Layer Properties > Style tab to adjust the image display? I'm playing with a SID right now and have found a couple ways to "darken" the image but it might be different than what you are hoping to accomplish. What are you wanting to do specifically?
-Carol
Carol Kraemer
On Wed, Mar 19, 2014 at 3:16 PM, Mike Keelan <tmike.elhoa at comcast.net<mailto:tmike.elhoa at comcast.net>> wrote:
Hello list,
Can anyone suggest how I would darken (overall) a .sid file?  The available parameters in the properties menu seems not to do the job?  Is it even possible?
I'm using Qgis 2.0.1 and windows 8
Thanks,
Mike K
<ELHOA Logo7.jpg>
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
<after.png>
<before.png>
[Lähettäjä poisti kuvan.]<http://www.avast.com/>
Ta wiadomość e-mail jest wolna od wirusów i złośliwego oprogramowania, ponieważ ochrona avast! Antivirus<http://www.avast.com/> jest aktywna.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140321/00046b65/attachment.html>
Type: image/jpeg
Desc: ~WRD000.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140321/00046b65/attachment.jpg>
