[Qgis-user] Is there way to print out a layered PDF-document?
    Joachim Józefowicz
    joachimjozefowicz at gmail.com
    Fri Mar 21 03:30:34 PDT 2014
If You use mapinfo You can save shapefile like a mapinfo file and then
save like You want.
On this moment I don't see another way. ( maybe from AutoCAD Dxf file
it's very fexible format. i've seen on web a lot of converters for dxf
to pdf)
------ Wiadomość oryginalna ------
Od: "Järnefelt Jouko" <Jouko.Jarnefelt at tampere.fi>
Do: "Joachim Józefowicz" <joachimjozefowicz at gmail.com>; "Qgis List"
<qgis-user at lists.osgeo.org>
Wysłano: 2014-03-21 11:13:00
Temat: VS: [Qgis-user] Is there way to print out a layered PDF-document?
>Hey,
>Thanks Joachim for your answer, and pardon me because I wasn’t clear
>enough.
>I know how to print out a PDF… but the thing what I’m trying to do is
>to print out a PDF-document that has preserved the same layers which
>have been active in QGIS workspace. This is possible in MapInfo but I’m
>interested to know if there is similar function in QGIS… or any
>workaround.
>Cheers to all,
>Jouko
>Lähettäjä: Joachim Józefowicz [mailto:joachimjozefowicz at gmail.com]
>Lähetetty: 21. maaliskuuta 2014 11:14
>Vastaanottaja: Järnefelt Jouko; Qgis List
>Aihe: Re: [Qgis-user] Is there way to print out a layered PDF-document?
>Of course.
>Project -> New Print
>In Print Window
>Print -> Export like a PDF.
>Do: "Qgis List" <qgis-user at lists.osgeo.org>
>Wysłano: 2014-03-21 08:02:08
>Temat: [Qgis-user] Is there way to print out a layered PDF-document?
>>Hey all.
>>I have a simple question for which I haven’t been able to find answer.
>>Thanks for your help!
>>Jouko
>>City of Tampere
>>Department of Land use and Planning
>>Finland
>>Lähettäjä:qgis-user-bounces at lists.osgeo.org
>>[mailto:qgis-user-bounces at lists.osgeo.org] Puolesta ELHOA
>>Lähetetty: 21. maaliskuuta 2014 0:41
>>Vastaanottaja: Carol Kraemer
>>Kopio: Qgis List
>>Aihe: Re: [Qgis-user] How to darken a .sid layer?
>>Thanks Carol,
>>I was able to darken my .sid layer using the method you suggested.
>>Turned out pretty good.
>>Mike K
>>Sent from my iPhone
>>On Mar 19, 2014, at 4:43 PM, Carol Kraemer
>><cakraemer at northrivergeographic.com> wrote:
>>>Mike,
>>>When I was playing with the SID I have, I was able to use a
>>>combination of tools under the Color Rendering section to darken and
>>>enhance the image. For example, I adjusted Brightness and Contrast to
>>>bring out the colors. I've attached a before and after to show the
>>>difference.
>>>Hope that helps!
>>>-Carol
>>>Carol Kraemer
>>>North River Geographic Systems, Inc
>>>http://www.northrivergeographic.com
>>>404.431.0125 cakraemer at northrivergeographic.com
>>>On Wed, Mar 19, 2014 at 4:23 PM, ELHOA <tmike.elhoa at comcast.net>
>>>wrote:
>>>Hello Carol,
>>>Yes on my attempted method.
>>>I'm trying to darken the photo, (.sid), so I can get more contrast
>>>with other layers which are overlaid on top of it; roads, parcels,
>>>rivers, etc.
>>>Sent from my iPhone
>>>On Mar 19, 2014, at 3:26 PM, Carol Kraemer
>>>>Hello Mike,
>>>>You've been using the Layer Properties > Style tab to adjust the
>>>>image display? I'm playing with a SID right now and have found a
>>>>couple ways to "darken" the image but it might be different than
>>>>what you are hoping to accomplish. What are you wanting to do
>>>>specifically?
>>>>-Carol
>>>>Carol Kraemer
>>>>On Wed, Mar 19, 2014 at 3:16 PM, Mike Keelan
>>>><tmike.elhoa at comcast.net> wrote:
>>>>>Hello list,
>>>>>Can anyone suggest how I would darken (overall) a .sid file?  The
>>>>>available parameters in the properties menu seems not to do the
>>>>>job?  Is it even possible?
>>>>>I'm using Qgis 2.0.1 and windows 8
>>>>>Thanks,
>>>>>Mike K
>>>>><ELHOA Logo7.jpg>
>>>>>_______________________________________________
>>>>>Qgis-user mailing list
>>>>>Qgis-user at lists.osgeo.org
>>>>>http://lists.osgeo.org/mailman/listinfo/qgis-user
>>><after.png>
>>><before.png>
>Ta wiadomość e-mail jest wolna od wirusów i złośliwego oprogramowania,
>ponieważ ochrona avast! Antivirus jest aktywna.
Ta wiadomość e-mail jest wolna od wirusów i złośliwego oprogramowania, ponieważ ochrona avast! Antivirus jest aktywna.
http://www.avast.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140321/62ccd36b/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140321/62ccd36b/attachment.jpg>
